no idle switch in haness?
datsunissan
Post by datsunissan »
Ok heres a question to stump you guys so there is no idle switch pigtail in my harness does anyone know what this would affect?
Re: no idle switch in haness?
Post by adamky »
I'm not even sure what an "idle switch" is...?
datsunissan
its the input to the front of your tps NOT the wires going to the tps
Post by adamky »
Can you post a pic? All the TPS sensors I've dealt with in my car have only had 3 wires going to them, so I'm still not sure what you mean.
Post by p00t »
My guess is you have an AT TPS but a MT harness. If you are running a manual trans dont worry about it, the ECU uses the TPS signal for idle (<0.52v = TPS closed).
