It's all fun and games until someone breaks a gas tank!
- shift_jin
Early today i went out for a slide in the 240 (not on a public road). Later today i noticed a wet spot under the gas tank on the ground. it is still leaking about a drip a second right now. it drips from the top and runs down, but it's not evident from the fuel pump axcess door. also keying over doesn't seem to make any difference so i am guessing it is not that easy of a problem.
i have been pondering on how it happened... i guess i won't know until i remove my tank.
contact me for 5 lug hubs, aluminum uprighs, z32 e-brake assembly, and z32 calipers
z32 part-outs
z32 part-outs
its behind the center strap by the diff. rocks get in there and make pin holes, seen it a many times times. I used turck bed liner on mine to keep it from getting holes after I saw several people with the same problems. btw that gas tank repair where you mash it together...no good. need to weld it (with no gas or fumes inside).
- Jordan Gladman
I would strongly suggest finding another tank... welding your gas tank is a bad idea unless you're incredibly thorough. A few drops of gas left in the tank could result in shards of 20ga steel in your neck.keytops wrote:its behind the center strap by the diff. rocks get in there and make pin holes, seen it a many times times. I used turck bed liner on mine to keep it from getting holes after I saw several people with the same problems. btw that gas tank repair where you mash it together...no good. need to weld it (with no gas or fumes inside).
- Walperstyle
I've welded them before, I normally clean the tank with acetone to get the varnish off the walls. Let it sit till the fumes are gone which acutally doesn't take long as you think it would, especially if its in the sun. Tack the areas that need repair. You have to have a air fuel mixture for any sort of combustion. Dont trust the movies, trust science. If there is no fuel then there is no problem. so make sure there is no fuel vapor or sitting fuel. Leaving it in the sun on a windy day really helps get all the little pools of gas out
Make sure to give your welds a good coating of POR15 or atleast some truck bed liner. Did you find the hole yet?
- Jordan Gladman
keytops wrote:I've welded them before, I normally clean the tank with acetone to get the varnish off the walls. Let it sit till the fumes are gone which acutally doesn't take long as you think it would, especially if its in the sun. Tack the areas that need repair. You have to have a air fuel mixture for any sort of combustion. Dont trust the movies, trust science. If there is no fuel then there is no problem. so make sure there is no fuel vapor or sitting fuel. Leaving it in the sun on a windy day really helps get all the little pools of gas out
You ever made a potatoe gun that uses gasoline?
Thats all I have to say......
- PandaPants
- Jordan Gladman
That was my point, you can take like 2-3 shots on a single spray of gas because once you reload it and get some more oxygen in there, the residual gas in the cracks of the fittings and where ever else is enough to get another decent shot, a small drop of gas can make enough vapor for a pretty powerful explosion.
You miss 2 little drops of gas in your tank when you go to weld and it will blow up in your face. With all the baffles and inaccessability in the tank, you'd pretty much want to pressure wash it inside and out before you even think about welding.
And while we're on the subject... slightly unrelated, but interesting.
