Noob question about a turbonetics turbo kit
sifudrifter
Post by sifudrifter » Wed Apr 07, 2010 2:02 pm
will a s13 turbonetic turbo kit fit on a s14???? if not what would i need???
Post by cleantune » Wed Apr 07, 2010 2:11 pm
*Clearance is key*
Problems include length/ angles of intercooler piping and the proximity of the downpipe/turbo/wastegate to the power steering and brake master cylinder.
Other than that as long as the kit was made for the DOHC, the manifold should bolt right up, and there are always ways of making things fit on cars :D
s13grady
Post by s13grady » Wed Apr 07, 2010 3:20 pm
yes it should fit with minor modifications and adjustments.
92 s13 ka24det sc61 project.
street trim sleeper
madd ocx
Post by madd ocx » Wed Apr 07, 2010 5:17 pm
did you find a used kit? cause I thought turbonetice stopped making the kits for the ka..
ka-t greddy 20g, enthalpy ecu, 440 injectors, ngk plugs and wires, bc v2 cams, megan catback, custom downpipe, godspeed fmic, safc 2, koyo rad, nismo thermostat, aem wideband, autometer phantom boost gauge, fidanza flywheel, spec stage 3+ clutch,j30 diff,n60 maf running 8psi!!
sifudrifter
Post by sifudrifter » Wed Apr 07, 2010 5:19 pm
im not sure...is new but im buying it from a private owner
sifudrifter
Post by sifudrifter » Wed Apr 07, 2010 5:20 pm
ight thanks guys
Arro
Post by Arro » Wed Apr 07, 2010 6:13 pm
Wait, when you say "S13", do you mean KA24DE (LATE S13) or KA24E (EARLY S13)? If you're asking a n00b question, I'd hate to think that you were getting ahold of a KA24E turbo kit and expecting it to work on the KA24DE engine. S13 had both engines.
-Jason Arro - Club-S12 Admin
'85 Silvia RS-X
'85 Nissan 200SX (KA24DE)
TanManS14 wrote:Hella flush and all associates should be gunned down for brainwashing people into thinking a 225 and lots of camber is proper wheel fitment
sifudrifter
Post by sifudrifter » Sat Apr 10, 2010 9:33 am
im not that noob.. :D i know the different between dual and single.....
Post by Walperstyle » Sat Apr 10, 2010 9:37 am
Its the same problems as if its a SR. Ask the owner if he can supply pics installed, if not, just search for someone with a turbo of the same size. and similar if not the same manifold.
