Noob question about a turbonetics turbo kit
- sifudrifter
will a s13 turbonetic turbo kit fit on a s14???? if not what would i need???
*Clearance is key*
Problems include length/ angles of intercooler piping and the proximity of the downpipe/turbo/wastegate to the power steering and brake master cylinder.
Other than that as long as the kit was made for the DOHC, the manifold should bolt right up, and there are always ways of making things fit on cars
did you find a used kit? cause I thought turbonetice stopped making the kits for the ka..
ka-t greddy 20g, enthalpy ecu, 440 injectors, ngk plugs and wires, bc v2 cams, megan catback, custom downpipe, godspeed fmic, safc 2, koyo rad, nismo thermostat, aem wideband, autometer phantom boost gauge, fidanza flywheel, spec stage 3+ clutch,j30 diff,n60 maf running 8psi!!
- sifudrifter
- sifudrifter
- Arro
Wait, when you say "S13", do you mean KA24DE (LATE S13) or KA24E (EARLY S13)? If you're asking a n00b question, I'd hate to think that you were getting ahold of a KA24E turbo kit and expecting it to work on the KA24DE engine. S13 had both engines.
-Jason Arro - Club-S12 Admin
'85 Silvia RS-X
'85 Nissan 200SX (KA24DE)
'85 Silvia RS-X
TanManS14 wrote:Hella flush and all associates should be gunned down for brainwashing people into thinking a 225 and lots of camber is proper wheel fitment
- sifudrifter
- Walperstyle
