JWT 350Z 6-speed gearbox swap
Not sure if this has been posted yet, but it's another option for a burly tranny behind a KA. Sure, some of the 350Z and G35 transmissions need a little rework eventually because of the synchros, but they're pretty beefy otherwise from what I know. Fairly plentiful and not too expensive either. Who's gonna run one first?
http://www.jimwolftechnology.com/news.asp News date 11/8/2010
the whole auto bell housing thing is wack. poor SR guys, thats not an easy score.
- eazye2000
That's what I'm talking about. I hate to bash, but it sucks when people keep things like that to themselves. I've burnt through about 10k, and a marriage to help find things that work, and don't work for this community.klattr1 wrote:yeah but have you been selling them to the public?smracing wrote:I've been doing trans swaps with the automatic converter housings for 15 years.
Other than that, sweet find.
I blame my anger on the holidays.
It looks pretty long. You'd definitely have to rework the shifter setup to get it to come through the stock shifter location at all. Something similar to what Xcessive does with their kit would probably do it.Bubba wrote:Good find. I wonder about the shifter location is all.
- street_240sx
Hmm first adapter I've seen like that. I think it'll put the shifter back a lot. There is a local guy that makes the adapter for sr20, me and a few others asked for them too make a ka one. Ill find a link to their ad on zilvia. Then there is a guy on ebay who can make one too.
The kit that is local, you have to mill the bell housing a little, shorten the shifter bracket. Make a custom crossmember too.
03 evo8 gsr: stroker 2.3
- street_240sx
- myowncasualty
- bmitchell_ga
Damn I junked my auto tranny
97 S14
329hp 320trq @ 13psi (on pump)
? @ 18psi (corn)
my build thread
viewtopic.php?t=51532&highlight=
E85, obd I con, Nistune, HKS hi-power exh, Fidanza flywheel, ACT 6-puck, K-Sport coilovers, Holset hy-35 turbo, Turbo Smart 38mm wastegate, HKS bov, JGS mani, mm's, & oil line kit, AMS fuel kit w/ 95pd inj's, lc-1 wb, Driveshaft Shop DS, Greddy profec b
? @ 18psi (corn)
my build thread
- k12ispl
i would so rock that thing in my 240, especially when ur driving 70mph at 3K rpms kinda blows with the stock transmission,
1993 240sx Coupe 5 Speed
*'91 Ka Rebuild w/ stock internals
*Stage 1 clutch
*Lightweight Flywheel
^July'12-Traded for a '03 zx6r 636
1969 Datsun 1600 Roadster Build
viewtopic.php?t=52915
www.intercarofknoxville.com
*Stage 1 clutch
- Covertpolarbear
the z33 transmission has a higher 6th gear than the ka's 5th, i believe you will actually be even higher in rpms driving on the freeway.. the z has a lower geared differential to account for that.
Max speed @ 7000rpms w/ 225-55-16 based tire
KA : w/ 4.08 : 240sx final drive
gear 1: 3.321 - 38mph
gear 2: 1.902 - 66 mph
gear 3: 1.308 - 99 mph
gear 4: 1.000 - 126 mph
gear 5: 0.759 - 167 mph
Z33: w / 4.08 240sx final drive
gear 1: 3.794:1 - 33mph
gear 2: 2.324:1 - 54 mph
gear 3: 1.624:1 - 78 mph
gear 4: 1.271:1 - 99 mph
gear 5: 1.000:0 - 126 mph
gear 6: 0.794:1 - 159 mph
- k12ispl
So swap it with a 300zx or a j30 diff ??Covertpolarbear wrote:the z33 transmission has a higher 6th gear than the ka's 5th, i believe you will actually be even higher in rpms driving on the freeway.. the z has a lower geared differential to account for that.
*Stage 1 clutch
*Stage 1 clutch
Max speed @ 7000rpms w/ 245/45r17 based tire
KA : w/ 3.916 (J30 VLSD) : 240sx final drive
gear 1: 3.321 - 41.12 mph
gear 2: 1.902 - 71.80 mph
gear 3: 1.308 - 104.41 mph
gear 4: 1.000 - 136.56 mph
gear 5: 0.759 - 179.93 mph
Reverse: 3.382 - 40.38 mph
KA : w/ 3.538 (Q45 VLSD) : 240sx final drive
gear 1: 3.321 - 45.51 mph
gear 2: 1.902 - 79.47 mph
gear 3: 1.308 - 115.56 mph
gear 4: 1.000 - 151.154 mph
gear 5: 0.759 - 199.15 mph
Reverse: 3.382 - 44.69 mph
http://www.angelfire.com/fl/procrastination/rear.html
LOL. I just was playing with the numbers so I wanted to know how fast I can go in reverse. So when you watch movies and they show a car in reverse staying up to speed with a car driving normally, there is some validity in it.
- street_240sx
Going to do a Z32 swap and wanted to see figures.
Z32 Tranny : w/ 3.916 (J30 VLSD) : 240sx final drive
gear 1: 3.214 - 45.98 mph
gear 2: 1.925 - 76.76 mph
gear 3: 1.302 - 113.50 mph
gear 4: 1.000 - 147.77 mph
gear 5: 0.752 - 196.50 mph
Reverse: 3.369 - 43.86 mph
supakat wrote:KA : w/ 3.916 (J30 VLSD) : 240sx final drive
Thank you sir. That is what I get for going by someone else's word and not checking on my own. I am going to update the posts. Q45 is 3.538.
http://www.nicoclub.com/archives/differ ... 240sx.html
- 240-kid
No problem.
I thought about the Nismo 6spd and adpating it for the KA but right off the bat you can tell its not gonna be very cost effective. Would be very nice for a N/A KA with the short gears you'd get.
I believe you can also use the 350Z Manual FD which is a 3.538 and they use a R200V IIRC but I can't verify or say for sure because I've never done it my self nor seen it. I believe when you do the gear of 1-5th is very very similar to our Stock Transfer and Different but with the extended 6th. I could be wrong though its been awhile sincerity played with the Z33 transfer idea.
I have a Z33 transmission and a KA auto bellhousing and I've been designing my own adapter plate. It's not a simple line up the holes and drill like other adapter plates - there are bearing surfaces and oil galleries that need to be incorporated into the adapter plate. When I finish my design I'll make sure it works before I sell a few and then put up the 3D model of it.
1973 Datsun 240Z KA24DET
Build Thread:viewtopic.php?t=52102&start=0&postdays= ... highlight=
- Kevin.Burmeister
^ yes please. then send me a price tag..Aaj2k5 wrote:I have a Z33 transmission and a KA auto bellhousing and I've been designing my own adapter plate. It's not a simple line up the holes and drill like other adapter plates - there are bearing surfaces and oil galleries that need to be incorporated into the adapter plate. When I finish my design I'll make sure it works before I sell a few and then put up the 3D model of it.
I am new to this whole trubo KA thing.. so the help is appreciated. >_<
92' 240sx vert
Manual swap
KYB coilover (junk)
Sparco seats and 4 point harnesses
Full Blitz 3" exhaust
B&M short shifter
Fully wire tucked (never ever ever again)
92' 240sx vert
Manual swap
KYB coilover (junk)
B&M short shifter
- street_240sx
Kevin.Burmeister wrote:^ yes please. then send me a price tag..Aaj2k5 wrote:I have a Z33 transmission and a KA auto bellhousing and I've been designing my own adapter plate. It's not a simple line up the holes and drill like other adapter plates - there are bearing surfaces and oil galleries that need to be incorporated into the adapter plate. When I finish my design I'll make sure it works before I sell a few and then put up the 3D model of it.
Same!
- Kevin.Burmeister
Now I may be completely crazy, but everything I find for the Q45 in alldata (or nodata, whatever you want to call it) says 1997-2001 have a 3.692 rear and the 2003-2005 have a 3.133 rear end. Am I just missing one being LSD and the ones I am finding are not?? The 3.133 rear would have wicked cruse in 6th.supakat wrote:Thank you sir. That is what I get for going by someone else's word and not checking on my own. I am going to update the posts. Q45 is 3.538.
Also, side note. The 2005-2011 Xterra, Frontier, and Pathfinder all have the same trans model as the 350z: FS6R31A. BUT they have different gear ratios;
1- 4.368
2- 2.518
3- 1.743
4- 1.283
5- 1.0
6- 0.769
All of those ratios suck even worse than the 350z except 6th. So with it being the same housing could you swap the 6th gear from the Xterra to the 350? I may be crazy and be just trying to justify this swap to myself.. food for thought.
92' 240sx vert
Manual swap
KYB coilover (junk)
B&M short shifter
92' 240sx vert
Manual swap
KYB coilover (junk)
B&M short shifter
- Walperstyle
