Sandwich plate or?
Sandwich plate or?
This is a really noob question but when I did my first KA-T setup I used different fittings connected together and had three fittings for oil feed, stock oil pressure, and oil pressure sending unit (electronic oil pressure). It looked something like this:
http://forums.nicoclub.com/oil-feed-lin ... 96306.html
I'm re-planning another KA-T setup and I don't plan to use that same setup because it doesn't look neat. What do most of you guys run? Sandwich plates? I want something that I can attach three fittings to and run the three things I mention above.
Any ideas?
Any ideas?
Kouki.Love.
- beercandrifter
i highly recommend the skullworks adapters, they are just hands down the sweetest piece of machining I have ever held in my hands, quality is amazing
http://zilvia.net/f/group-buys/301711-s ... d-2-a.html
just run a remote oil filter adapter and you are all set
- R34SR
http://cgi.ebay.com/ebaymotors/OIL-FILT ... ccessories
I have no clue why someone would pay $145 for something that essentially does the same job as a sandwich adapter...........oh and i personally own that glowshift one and it has 0 issues.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
Mazworx z32 tranny swap
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
I have one as well. I can't complain.revolutionz_s13 wrote:+1 for skullworks. Great quality part.
Very nice quality parts.
Good way to support shops that are still building things for the KA as well. Much rather my money go to them than a knock off company for something like this.
- Jordan Gladman
Dont use sandwich adapters unless you're running inline oil filters to your turbo and gauges etc. The oil you're drawing from is unfiltered and if you run this to your turbo you're going to pump oil pan particulate right into your turbo's bearing.
I ran one previously, never again though.
The DOHC oil filter block has a set screw below the factory pressure sensor that you can pull out and replace with a fitting. This is the ideal situation IMO.
Thought the oil coming out of those ports was unfiltered.. Seems like a big plus to relocation would be filtered oil.
I am thought about drilling and tapping the stock filter block to connect AN lines where the holes for oil are under the filter... not pretty but it might work really well.. havent looked into it to see if its physically possible
- beercandrifter
dont know why you would complain about the price of a remote oil filter adapter. it was 13$ for one when I bought it and you dont have to run braided lines and expensive fittings, granted its much cleaner, but the high pressure lines you can get will more than handle the 75psi the oil pump pushes out
either way, dont forget to order the gasket to put behind the adapter or stock piece if you take it off, autozone and advanced auto dont sell it outside of a full gasket kit.
this piece:
http://www.courtesyparts.com/15239-gask ... 64622.html
this piece:
I'm pretty sure my sandwich plate serbs filtered oil. And I'd not, it was filtered when it went through the filter into the engine (because it is constantly recycled).
http://www.areasoundmusic.com
I guess I'll go with this setup. I will just make two fittings out of that "set screw" for the feed and oil pressure sensor. Or is this setup not filtered either?Jordan Gladman wrote:Dont use sandwich adapters unless you're running inline oil filters to your turbo and gauges etc. The oil you're drawing from is unfiltered and if you run this to your turbo you're going to pump oil pan particulate right into your turbo's bearing.
And I really like that oil sandwich adapter by Glowshift but if it doesn't filter my oil it wouldn't be safe!?
Kouki.Love.
- eazye2000
I think some of you guys have it backwards....
If you use a sandwich adapter, the oil comes out of the block into the threaded part where the filter screws onto the post. Then the oil coming out of the filter, is filtered, and goes out the holes in the side of the sandwich adapter. I don't see how anybody can not see/picture this...
And the ports on the side of the factory oil filter housing are not filtered. They come out of the casting before the filter.
I will draw a picture if I need to, but I would really hope that this makes sense to you guys. If not, *facepalm*
With that being said the Glowshift sandwich adapter is a-OK correct? If so, I'll be ordering one soon.eazye2000 wrote:I think some of you guys have it backwards....
Kouki.Love.
- Jordan Gladman
Im not sure, my understanding was that the oil returned to the block through the center of the filter. Concider the design of the anti-drain back valve, If the oil was flowing out of the perimeter holes of the filter, the pressure would close the valve and block flow. The oil enters the filter through the small perimeter holes and returns to the block through the center. The factory pressure sensor gauges pressure at this point, it wouldnt make sense to gauge the pressure pre-filter as a blocked filter wouldnt show accurate output pressure.
Also, the OEM pressure relief valve is located on the outside of the filter, if the filter is clogged, it bipasses into the center.
Last edited by Jordan Gladman on Tue Feb 08, 2011 10:27 pm, edited 1 time in total.
- Jordan Gladman
Although its true that the oil is circulated and mostly clean as it passes through the sandwich, if you're breaking in a motor you are going to have a period of operation where you will have constant metal particulate flowing into the filter. Having a sandwich will almost guarantee a blown turbo if you run a sandwich without filter. The turbo becomes one of the most important components on your motor that requires filtration when you install one, sandwich adapters are a big no no in my books these days.
I cooked 2 precision T3/T4's on my rebuilt motor running the glowshift sandwich plate. Im not sure why they went, but I suspected the sandwich adapter. When I switched back to the OEM pressure port, my turbo held up fine.
Last edited by Jordan Gladman on Tue Feb 08, 2011 10:33 pm, edited 1 time in total.
- Jordan Gladman
You can buy inline oil filters for your turbo feed. This will pretty much guarantee clean oil to your turbo.
http://cgi.ebay.com/ebaymotors/Turbo-Dr ... arQ5fParts
Magnetic drains are a joke IMO. They collect stuff, but the are pretty random in their functionality.
I will see if I can get a pic of the filter neck. i put mine on last week.
So alot of debating whether one or the other is filtered, now I don't know which theory to believe.
I was looking at the sandwich plate posted by R34 from earlier on in thread. I suppose if I don't go with the Glowshift sandwich plate I'll just tee the fitting from the hole below the stock oil pressure sensor?
Kouki.Love.
- 98blackkat
lol no that wouldn't work.98blackkat wrote:heres an Idea the t fitting is known to be filtered oil right. adn the big advantage of the sandwich is no drilling holes. why not just use the sandwich for the return or would that not work
Drain is gravity only. At the sandwich you get pressurized oil. If you somehow connected a turbo drain to it, you'd be pushing oil the wrong way.
- 98blackkat
it is simple. cut hold to spec. tap then screw in and weld. if have a tig, good. mig is a pain but if anything brass it. i like solder because it is easier to fill and control the metal.98blackkat wrote:yea that would be bad. thanks for the info. (first turbo set up) not looking forward to drilling into the pan
- 98blackkat
