Wheel fitment front 17x9.75?
Well I just realized there is no dedicated suspension or wheel section on this forum. I guess this will have to do. I would ask on zilvia but I value the knowledge on this.
This is on an S13
I am ordering the new xxr 527's today or tomorrow ( Feel free to hate) as I have no need for expensive wheels. For the rear I am set on the 17x9.75 +25. Now my question is for the front they have either the same size or 17x8.25 +25. Just curious if anyone thinks I can run the 9.75 on the front without to many issues, or should I just go with the 8.25 up front and call it a day. I'd rather go with the 9.75 all around but the et25 is kind of a limiting factor. I guess I could play the spacer game.
Lets hear some input.
You guys rock.
-Mark
Edit: Because I wrote Figment.
This is on an S13
You guys rock.
-Mark
Do work and let work do.
- Jordan Gladman
I ran 17X9.5s up front -6ET. I had to pull the liners and hammer down all the seams.
- eazye2000
I just ordered the 527's in the 17x9.75's all around for my S13. I have Megan coils, so I opted to get the extended lower brackets in case I need them. I'm also fully prepared to hammer/cut/bang/weld whatever needs some 'persuading'...
When they come in, I'll update on how they fit with Z32 brakes, and regular coilovers. I will also let you know if I need to use the extended lower brackets. I really don't want to run spacers, as a few of the classes of auto cross don't let you run them.
But yeah, mine are ordered. Let you know when they come in. Hopefully next few weeks.
i actually just saw these on a red cobra twenty minutes ago. my most def next wheel of choice over xxr.
- Jordan Gladman
Going 5 bolt def opens up a wider range of possibilities for wheels...
You can get sick staggered wheel combos w/ stickie tires from mustang sites.
17X9's +25 up front on stock fenders.
Check out this site and some of their stuff, this is where I ordered 2 different sets of my cobra wheels.
315 Nitto's!
http://www.cruizinconceptswholesale.com ... ANDTIREPKG
More wheels.
http://www.cruizinconceptswholesale.com ... s-rims.asp
315 Nitto's!
More wheels.
jordan, I wish you had pics with these rims in the light. the garage hides them.
NL Motoring. on Dec.6th.......they have no eta on ship date. when i called xxr directly they said theyd be shipping to NL in marchDEEPfrom1 wrote:\sh1tsweak wrote:i ordered 2 sets of 527's in the 17x9.75 back in the begining of december and havent gotten them yet so good luck with that lol.
Where did you order from?
When i order these tires, I will see if I can upgrade to 315/35r17. if i cannot, i will just burn out the 275's and get these.
http://cgi.ebay.com/ebaymotors/1-NEW-31 ... 725wt_1086
- Jordan Gladman
They didnt look bad, however the 10.5's in the rear were HEAVY. 55lbs with tires I believe. When I switched to the machined faced 03' cobra wheels they dropped down just over 10lbs each! I personally got tired of them very fast, the front wheels with the rounded spokes got cheap looking fast. I loved the 03' cobra wheels, Im still trying to figure out how I can get a set to fit my S2K.supakat wrote:jordan, I wish you had pics with these rims in the light. the garage hides them.
Here are some better pics.
Last edited by Jordan Gladman on Tue Feb 22, 2011 4:33 pm, edited 1 time in total.
- Jordan Gladman
If your coils dont have camber adjustment on the top bolt of the spindle connection, you can elongate the hole to gain adjustment. I've done this before and I had to do this to get the stang wheels to fit. You can die grind the hole or if you have a small bridgeport you can use a mill.DEEPfrom1 wrote:Eazye: Keep me updated man, if they clear the megans they should clear my stances.
Jordan: Those Cobra wheels don't look bad.
thanks jordan. i wonder how they would look like with rivets. but i am scared about the weight and looking for oem cobra wheels. then get 315/35r17 tires.
