Where can i get Ngk bkr7e's?
Is frsport the only place that sells them? Or does anyone know if any parts stores sell them?
Check Advance, Autozone, and Napa and they dont carry them.
Trying to get them gapped at .28 for my t28 setup sitting in my room.
Thanks,
-Marc
Thanks,
-Marc
all those parts stores have them. they dont know what bkr7e means, the know 6044... i could be recalling it incorrectly but if you look up bkr7e on this forum youll find the old and new p/n's.
- carcrzy920
Try NGK BCPR7ES (3330) if you want to live on the edge.
I have had good luck with them.... they are for a 7mgte toyota supra... One of the more knowledgable members was talking about using them. They seem to foul less and work very well. Not to mention, they are usually in stock.
I use BCPR6ES (2330) since im on e85 and lower power.
found it!
foltzs14 wrote:Hey I just wanted to spread the word that when going to an automotive store and purchasing some BKR7E's, they have a new part # which is #4644 (2002 Jeep Cherokee Overland V-8, the old part # was 6097). The price has gone up a little bit as well. Just wanted to pass the word along.
Those are pre gapped to .45 instead of .35 iirc.
- joshpntbl07
- Kfred
I work at advance auto parts and we always have bkr7e, bkr7e11, bcpr7es, and r5671a-7 plugs in stock. All will work great, but i have the best luck with bcpr7es plugs.
You can't cross reference bkr7e in the computer, but we carry them. Generally, if the guy/gal is at the counter can't find it in the computer, it doesn't exist. Look up the most current stock number and go into the parts stores with part numbers on hand. If it was up to me I wouldn't let most of my coworkers handle a broom, much less look up parts on a computer.
RIP Nate(480sx)...
- smracing
They are gapped at 1.1mm (.043), not .011. I prefer the R5671A-7, because it does not have a projected tip. Also the cheapest. I run the R5671A-10.Nkelley wrote:these plugs are a common honda motorcycle plug. the honda shop will sell them as bkr7e-11 which just means they are gapped at .011" easier to find in a motorcycle shop by far than an auto parts store. just fyi
i got my bkr7e's from sparkplugs.com the part number is 4644.. frsport told me some stupidness about 40 something dollars for iridium plugs..
ka-t greddy 20g, enthalpy ecu, 440 injectors, ngk plugs and wires, bc v2 cams, megan catback, custom downpipe, godspeed fmic, safc 2, koyo rad, nismo thermostat, aem wideband, autometer phantom boost gauge, fidanza flywheel, spec stage 3+ clutch,j30 diff,n60 maf running 8psi!!
I bought mine at advance and autozone, and have used both copper and irid, both ran well, couldnt see much difference. schmauster920 did you ever have any fouling issues with those ? I was tempted to try but read that large gap would foul, so I stuck with the norm, maybe your E85 helps?
92 Coupe - forged internals - stage 2 cams / ss valves
Aem Series 1 - Billet 50 Trim - ram style manifold- Aero 340
Hydro Ebrake - JSK coilovers - ISIS Rucas - Hicas rack - Ksport BBK
tKfred wrote:I work at advance auto parts and we always have bkr7e, bkr7e11, bcpr7es, and r5671a-7 plugs in stock. All will work great, but i have the best luck with bcpr7es plugs.
Dude I love Advance but your sooooo right. If its not in the computer it doesnt exist...story of my life. I would say to my self, how come know one but the internet sells these plugs, it cant be. Had to settle for 6e because 7e DIDNT EXIST.
Didn't read all this, but BKR7Es are part number 4644. Any advance/autozone can search that part number and find them.
- emo_tactical9
They also show under a 2001 Integra Type R.
