vacuum questions
vacuum questions
There be another thread so please re direct me, but i did search first and didnt find anyhting concrete. I have a t25 with the hks waste gate and stock bov and i was wondering where is should run there vacuum ports to. i also have a posssible nipple on the smic piping
Anything off of the manifold behind the throttle body. I teed off of my fuel pressure regulator line. One thing you could also do is use a vacuum block on the brake booster hose.
This is a good place to start.airman wrote:Anything off of the manifold behind the throttle body. I teed off of my fuel pressure regulator line. One thing you could also do is use a vacuum block on the brake booster hose.
Another note is that you can not use the nipple on your SMIC. It is positive pressure, and you need a vacuum source for the BOV.
- Walperstyle
lol one day I was driving along and suddenly the car started to buck. I limp it home and pop hood to find black smoke everywhere. I peer behind my turbo and I see what looks like oil all over the exhaust housing where the elbow meets. I thought I had blown the turbo. Then it cooled down, and the "oil" hardened, and I realized that it was the clear line, had melted all over the elbow and caused massive vac leak. Since then it has been replaced and the lines are now inside some shielding to prevent same issue =) so never use the provided hose with boost gauges, even for testing purposes!Walperstyle wrote:^lol, we can ignore the clear hose, but the heat from the turbo wont!
95 240sx KA24DE-T
S15 Injectors
Z32 blow through
S15 Injectors
Z32 blow through
I'm not sure what you mean. If you mean how to set/ change psi max of wastegate you can do so with a boost controller (and w/ aftermarket external WG with different springs, to some extent)nickuab wrote:so just so im clear, a vacuum block should go in the brake booster line and that shoul have both the bov and wastegate, but how do i control the pressure
