Cant decide between precision 6262 or 6266
I can decide whether to go with the precision 6262 or the 6266. I have 1000cc injectors stock throttle and intake manifold, wisco pistons and eagle rods , stock crank, aem ems and 38 mm wastegate, also have a mishimoto radiator to cool the engine better. I already know that the ka24det cant handle high rpms like past 7000 without evenually tearing stuff up. So would a 6266 do the job with a .63 a/r because of the boost will kick in around 2000-5000rpm but the .82 a/r would kick in around 4000-7000rpm. need help
- franman
using a .63ar housing on the 6266 will choke up the exhaust side quite a bit, although spool will be slightly better than the .82 housing the engine will not actually be able to take advantage of the larger compressor wheel. Do you have a # in mind you want to make? What fuel will you be using?
enjoy the build, sounds like your well on your way to a solid set up!
