oem oil pump or no?
andarou
oem oil pump or no?
Post by andarou » Wed Apr 11, 2012 5:28 pm
I'm by no means an advanced engine builder or anything, but I'm rebuilding my ka24de while I have it on the ground.
I'm replacing most of the accesory external parts (water pump, timing, alternator, etc)..
I was in the process of purchasing a new oil pump, and I figured I would go with something that put out a bit higher flow.. then I read thru some pages that said if you have a higher flow rate from the oil pump, you could essentially over lubricate or run the oil pan 'dry'
I'll be using the stock oem oil pan..
Should I stay OEM, run a high volume oil pump, or a high pressure oil pump?
I know I would run 1/2 or 1 quart more oil to compensate, but I figured the lubrication provided by the upgraded pump would keep things a little better off.
If I upgrade the pump, can anyone tell me what else i would need to modify to make this increase operational?
240-kid
Post by 240-kid » Wed Apr 11, 2012 5:58 pm
Shimmed OEM Pump.....
NeverSatisfied
Post by NeverSatisfied » Wed Apr 11, 2012 6:49 pm
I'm not sure but from the research i've done on it, i've read the "high flow" pumps are essentially just oem pumps anyways. If you do decide to replace the pump, get the pump from the dealer.. the only other aftermarket pumps ive seen were all topline, and thats just a disaster waiting to happen. Only thing that sucks is for some reason, oil pumps are expensive as hell. Just dishes out 380.00 for mine. But its better than having a cheaper pump fail. Sometimes you gotta bite the bullet. >_<
If its worth doing, its worth overdoing.
Post by Walperstyle » Wed Apr 11, 2012 7:02 pm
Lots of fellas here making good power have a stock oil pump. Get a good oil pressure gauge, and pay attention to it. Then, if you kill a couple of OEM oil pumps, consider aftermarket.
andarou
Post by andarou » Wed Apr 11, 2012 7:32 pm
Thanks guys.
I just wasn't sure if it's something like a water pump that should be changed if it's already out, or I could keep it in (not sure the mileage on the motor)
thesandman4444
Post by thesandman4444 » Wed Apr 11, 2012 7:59 pm
I've got a Beck arnley timing cover and oil pump with 60k on it. It still makes 22 psi at 1000 hot idle with rotella 15w 40 so its definately not wearing abnormally. It was a bit cheaper than the OEM and you can see where they actually ground the Nissan logo off the casting on the cover.
built block, sls manifold, 60 trim t3/t04e, rc 750s and nistune
Post by Walperstyle » Wed Apr 11, 2012 11:06 pm
OP, are you asking about an Oil pump, or Water pump... you are confusing us.
