Where to buy "Walbro 255" locally for < $70 in a pinch
Re: Where to buy "Walbro 255" locally for < $70
Post by schmauster920 »
Thanks for the sticky
Taking2long
Post by Taking2long »
Man pair that with some STI injectors and z32 fuel filter from Rock Auto and you got a complete fuel upgrade for cheap.
Empire087
Post by Empire087 »
Things seem to be working fine, not sure why i had the problems i did but all is good now.
Current rides:
2004.5 Silverado 2500hd ccsb 4x4 LLY Duramax
2009 Crossfire 1000 sno pro LE
(Potential):1991 Coupe 5spd
Previous:
1996 D21 4x4 5 sp ka24e-t
Caveit77777
Post by Caveit77777 »
What did you guys do as far as the wiring goes for the E2448 pump since the s14 harness won't fit on it? I popped the two wires out of the harness (the one already in the car) and it looks like I can connect them each directly to the two prongs sticking out on the pump. I was going to do this but I wasn't sure if the current would still flow on a connection that is fully submerged in gas. The harness looks like it protects the wiring so I don't want to run open connection in gas if it's not safe.
1996 Zenki: Arias 8.8:1 Forged Pistons, AMS Sportsman Series Rods, Tial 38mm, 370cc, Fel-pro Gaskets, New Stock Crank, Nismo Thermo, Nismo Mounts, Dual Canister Exhaust, Walbro 255, T3/T4 Turbo, Mishimoto Rad, Isis Fans, HKS SSQV, SPL Tension Rods, GAB Revo Sport II Coilovers, Enthalpy Tuned... more to come
240-kid
Post by 240-kid »
It'll work, just make sure you put something between the 2 prongs to keep them from ever touching.
when I installed this on a friends EK, I broke off a piece of plastic from an old connector and shoved it between the 2 prongs and ziptied the wires together to wedge the wires against the plastic to keep everything together.
So far so good.
Though the FP is suppose to come with a Connector in which you would just splice.
mitcheyismyname
Re: Where to buy "Walbro 255" locally for < $70 in a pinch
Post by mitcheyismyname »
Have to look into this.
SolTNutz
Post by SolTNutz »
Not a fan of walbro, have had trouble in the past and switched to bosch years ago. Not saying all walbro are bad but read the link below. That is why they are on sale a lot.
http://realstreetperformance.com/Fuel-P ... -Test.html
Post by airman »
Bosch 044 is the way to go :)
These $70 Walbros are good for when the Walbro you are using dies on you haha XD
321Ricky
Post by 321Ricky »
So if I were to get two of these my a dual set up I should be fine?
Post by airman »
It's a cheap and effective solution; you get what you pay for but so far I believe these pumps hold up fine.
