Precision turbo oil restrictor
I'm about to put on my 6262 journal bearing and wondering if I'm supposed to use an oil restrictor. I see a lot of mixed answers on it. But I figured someone would chime in here on it. Thanks.
Built ka-t
Arias 8:8:1 .20 over
K1 rods
Arp head,main,rod studs
Cxracing fmic
Proefi pro128, e85 flex fuel
K1 rods
Cxracing fmic
For a journal bearing turbo, most people will suggest that a oil restrictor is not needed (especially for a high-end brand name like precision).
I don't run one on my Holset HX35 turbo and have not had any problems. Many others will tell you the same thing.
precision says dont worry about a restrictor on a journal bearing unless pressures regularly pass 90psi. that was WES who said that. he also stripped my turbine blade bolt and sent me back my turbo saying it wasnt worth a rebuild - so greain of salt, might want to call yourself.
I was told that the Precision ball bearing turbos already have an oil restrictor built-in, so it's not needed. Don't know about journal bearing turbos though.
Thanks for the replies fellas. I have -4an feed line so I think I'm gonna try no restrictor . If it starts to smoke then I'll throw in my restrictor in. Just so many mixed answers on the interwebz.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
What you need to do is look at your oil psi. If above recommended specs, then run a resistor.
Never thought of running a screen. I never did on my Garrett t04e. What kind do you use? I also -4an feed line that's why I ask.KYLEBRENAY wrote:I have a 6162 journal bearing and -4an with no restrictor for almost three years now with no issues. However, I do run a screen catcher right before the turbo just in case i get a particle that wants to go through.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
Thanks bro I need to make some changes to it. I just put on a peakboost manifold and a precision 6262 .82 a/r. Can't wait to drive it.
Built ka-t
K1 rods
Cxracing fmic
K1 rods
Cxracing fmic
