rebuilding block again. e85 this time?
I fried the pistons, and cracked the rings on my ka-t because of a bad tune. I'm rebuilding her again and this time I was thinking about running e85. I don't want to change my setup, except for a re-tune of course, how much power can I squeeze out as is ? I have:
810cc side feed injectors
255lph walbro
stock FPR
t3/t4 60 trim .63 AR
255lph walbro
stock FPR
Might max out around 400whp. Injectors will hold you back from more power safely.
Actually that you point that out, I would buy a rising rate fpr. As for lines, I replace all the rubber lines in rear and front. Stock metal lines still there. No rust in my fuel filter. The coldest it gets here is around 40* but on a good week, it is around 55*. No issues with those temps.
A member here made 410hp on a walbro and e85.. The walbro maxed out right after that though.
I keep a set of ecu chips with my e85 tune in the glovebox.
- Walperstyle
I maxed my 880's out on 15 psi with my 60-1 turbo. You will be no where near 400 whp with 800cc. I switched to 1200cc and still on a single walbro. I don't have any adverse cold starts and I've been on e85 for over a year. I dyno'd a couple of weeks ago and did 370 wheel on 17 psi. No maxing of anything. I keep an eye on fuel pressure (in car gauge). I am still running all the stock rubber lines as well.
Broken link is broken
Just saying. Crank that FPR up with a decent size turbo.
http://www.youtube.com/watch?v=g6RDqSwt ... e=youtu.be
The only place my car is really happy is around 50 base, so 60psi isn't absurd, just make sure your hoses/fittings are in good shape.Toe wrote:I didn't think about running 60 psi of base pressure. I was running stock base.
- R34SR
im only making 265hp 284tq but the isis fpr has been nothing but a charm to work with.Walperstyle wrote:curious, anyone here making good power with an ISIS FPR? SR or KA? ...or any engine in the 2.0-2.6 range?
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
Mazworx z32 tranny swap
CTS V CALIPERS
STANCE LX+ Coilovers
J30 LSD
AME FS01 WHEELS 18X9 +25
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
mustang dyno? cuz a dynapack would be over 450. not that the number is more important then the curve though.Toe wrote:I maxed my 880's out on 15 psi with my 60-1 turbo. You will be no where near 400 whp with 800cc. I switched to 1200cc and still on a single walbro. I don't have any adverse cold starts and I've been on e85 for over a year. I dyno'd a couple of weeks ago and did 370 wheel on 17 psi. No maxing of anything. I keep an eye on fuel pressure (in car gauge). I am still running all the stock rubber lines as well.
