grenaded my trans on the way to the trac(video)
Was on my way to go see some badass cars race,not even race and started hearing a noise well it kept getting progressively worse. Here is the video
http://youtu.be/j_Lwbq2n65s
89 sohc hatch t25 12psi. E60 blowthough ftw.
Yeah idk was even getting on it or anything just doing like 75 on the highway for 45min then got off on a exit ramp got back into 1st and started hearing the noise bad. It just kept getting louder then is started to sound like the video. O and plus I had 67 mile tow back to my house which cost 256 bucks
Lol stupid spammer
That sucks about the trans, sounds the bearings just went out or something.. I have been beating on my trans for a long time without any issues at all. I have had bearing / input shaft noise for a really long time though.
They always really pretty bad when the shifter is out, but not that bad lol
The tow truck ride home is what scares me, its more than the damn parts lol
Ive got a few friends with AAA where i can slide them 40-60 bucks and I get towed. Since they get like 3 tows a year and dont use their allotted tows, why not? You should ask around if any of your buddies has it.
- shift_down
Pulling the tranny from the bottom is super easy. Don't pull the motor, its harder that way
- Walperstyle
- shift_down
Good point. What I did was loosened the engine mount bolts all the way but leave them on.Then I loosened the 4 subframe bolts all the way but left them on. Then jack up the motor from the oil pan(use a block of wood), then that will tilt the motor which makes it A LOT easier to put the tranny back in. But make sure you have a way to lift the tranny, its a heavy mo fo. I'm only 155lb and 5'7 and I did it by my self with a only a scissor jack lol. So you can do it.
- emo_tactical9
Should have just called them directly.jsd21hb wrote:I got road side on my insurance so I should get reminbursed. I hope. Still need a damn trans now
I post pics when I get it out and apart
I abuse the hell out of my roadside asssitance. $1.33 a month and I think i have had all 3 of my cars towed twice a year since i've had it.
- shift_down
Oh god.
- nismoautoxr
ive had the same thing happen a couple times . Youll probably get it apart and find the teeth stripped off the main shaft gear and or the countershaft gear.
Ricky Ragan,
Z32 Box!
