What guages are you all running?
Jmoore124
Post by Jmoore124 » Wed Dec 12, 2012 7:40 pm
I will post more details of the Ka-t I am working on in the near future. It was a former members that I have been put in charge of finishing. It will have in the 450+ range and I want to make sure I am aware of any problems as soon as they arise. Boost, oil pressure are musts of course. But how many of you run EGT, Wideband 02 etc?
Post by Walperstyle » Wed Dec 12, 2012 8:28 pm
AEM series two with all AEM Gauges.
Any will work as long as it works. Besides, if you have a bad tune, or something goes wrong, you won't be always able to save it even if you do see it. It depends on when and what goes wrong. Temperature, heat, things like that often take longer then lets say a crazy lean mixture at 7500rpm. :lol:
Jmoore124
Post by Jmoore124 » Wed Dec 12, 2012 9:16 pm
Completely understand that. Things happen fast, especially with boosted motors. I want to give myself the best fighting chance. I know some companies make individual cylinder EGT probes and motoring systems, just curious if they are utilized in these type of applications and if there is anything else I am missing. There is a great deal of money tied up in this build, and I would hate to see it go south because I was not keen enough to have proper engine management instruments installed.
mmmS13
Post by mmmS13 » Wed Dec 12, 2012 9:54 pm
Currently im only running 2 gauges, an AEM wideband and an Autometer boost gauge. The wideband is probably the best thing I could have ever bought for my car. Its nice to know your air fuels when you go to bump up your boost a bit for those nights where your cars running really good. (personally not my method but I have a few friends that would do that) After owning a wideband I probably wouldn't own another boosted car without one.
I plan on buying more gauges in the future but im only pushing around 300hp and my motor has had a nice life (230k miles). Once that goes Ill get a bunch more gauges.
230k stock block
50 trim 16psi
810cc DW's
Enthalpy Tuned
*Sold*
Evo X Cornfed
http://www.youtube.com/LGmmkay
^ Youtube Channel ^
viewtopic.php?p=496648#496648
^ Build Thread ^
^ Considering E-Mance? Read this ^
Post by street_240sx » Thu Dec 13, 2012 3:04 am
240: stri xline and aem
old evo: defi blue racer and innovate wideband
current evo: stri,oem mitsu, and innovate lc1
im a huge fan of stri gauges
Post by beercandrifter » Thu Dec 13, 2012 5:05 am
i have autometer gauges (ultralite) in the car at the moment, dont really care for the night time lighting in them, but they look nice during the day.
primaries:
water temp, oil pressure, wideband
extras:
boost/vac gauge
oil temp
with megasquirt, i have my digital gauges set up for:
rpm, boost/pressure, coolant temp, wideband, voltage.
soon as I get ms3 in, will be adding oil pressure and fuel to the digital cluster. will be dropping the stock cluster from the car as soon as i have a fuel gauge and just run one big rpm gauge and the digital display next to it.
Freise
Post by Freise » Thu Dec 13, 2012 1:32 pm
Autometer cobalt gauges, work nice and are back-lit instead of the usual single led shining on the gauge face
And innovate wideband O2, I'd argue the wideband is the most important gauge you could have
95 240sx KA24DE-T
S15 Injectors
Z32 blow through
Post by shift_down » Thu Dec 13, 2012 2:31 pm
Wideband
Oil pressure
Boost
Empire087
Post by Empire087 » Thu Dec 13, 2012 6:00 pm
I'm running:
Aem wideband
Sunpro/glowshift boost gauge(when it gets fixed)
Ultra gauge w/rpm, water temp, timing, mpg, trip meter, instant mpg, avg mpg, and just about every other gauge I would like.
Current rides:
2004.5 Silverado 2500hd ccsb 4x4 LLY Duramax
2009 Crossfire 1000 sno pro LE
(Potential):1991 Coupe 5spd
Previous:
1996 D21 4x4 5 sp ka24e-t
Jmoore124
Post by Jmoore124 » Thu Dec 13, 2012 7:34 pm
How do you like the ultragauge and from where does it get its input signals?
wannabethestig
Post by wannabethestig » Thu Dec 13, 2012 9:15 pm
Oil pressure and wide bands are a must. Water temp, oil temp and boost are extras. Autometer phantom and plx. Im also not crazy about my backlighting.
Post by supakat » Thu Dec 13, 2012 10:38 pm
Nice gauge layout. The only thing I hate about having gauges there, is your eyes tend to wander. I have mine on the a pillar. I know it is fast and furious days but at least my peripheral vision still picks up obstacles if they appear.
I have boost/vacuum, wb02, and oil pressure. I need to pick up a water temp gauge.
Post by schmauster920 » Thu Dec 13, 2012 10:59 pm
I put a WBO2 bung in my oil pan and I use a cheap full sweep water temp gauge for oil temp, works great.
Having them down low helps not blind you, along with hiding them.. I need to install some resistors or bulb caps to dim them down a little. You can also hook them up to your stock dimmer switch.
vrtgli
Post by vrtgli » Fri Dec 14, 2012 2:01 am
All about autometer
Not cheap and the don't fail
john hand cock
Empire087
Post by Empire087 » Fri Dec 14, 2012 8:25 pm
Jmoore124 wrote:How do you like the ultragauge and from where does it get its input signals?
It's the one joy to obd2, it's a little slow for rpm, but its a great tool to keep the wiring down. It plugs into the obd2 port on factory cars.
Current rides:
Previous:
Jmoore124
Post by Jmoore124 » Fri Dec 14, 2012 8:40 pm
Thanks for all the help you guys. I already had a zeitronix data logger, so I went with the Zeitronix LCD display that displays EGT,AFR, ambient temp, and Boost. Although the greddy electronic boost controller already has one, redundancy is a good thing right? :lol:
Wannabethestig: is that panel something you made yourself? I know mine is slightly different, I have a double din HU. I like that setup. That is where I have my gauges in my 9 3.
Caveit77777
Post by Caveit77777 » Fri Dec 14, 2012 9:21 pm
AEM Wideband
GlowShift Boost Gauge
Next up will be an oil pressure gauge. Might stick with AEM to continue the theme but I reallllllly like the Pro Sport ones and they're affordable as well.
1996 Zenki: Arias 8.8:1 Forged Pistons, AMS Sportsman Series Rods, Tial 38mm, 370cc, Fel-pro Gaskets, New Stock Crank, Nismo Thermo, Nismo Mounts, Dual Canister Exhaust, Walbro 255, T3/T4 Turbo, Mishimoto Rad, Isis Fans, HKS SSQV, SPL Tension Rods, GAB Revo Sport II Coilovers, Enthalpy Tuned... more to come
wannabethestig
Post by wannabethestig » Sat Dec 15, 2012 11:40 am
Jmoore124 wrote:Thanks for all the help you guys. I already had a zeitronix data logger, so I went with the Zeitronix LCD display that displays EGT,AFR, ambient temp, and Boost. Although the greddy electronic boost controller already has one, redundancy is a good thing right? :lol:
Yes i built it myself. Used some wood i had laying around. Used the old.beatup tywrapped one as a template and arranged everything a couple of different ways before i settled on this. Ended up taking it apart again because i couldnt get the wood finish to look the way i wanted. It Was also a good excuse to rewire the rats nest that was behind there. The wood allowed me to recess the 12v too btw.
wannabethestig
Post by wannabethestig » Sat Dec 15, 2012 11:41 am
I can post up a pic of the back if you want.
BADA$$240
Post by BADA$$240 » Sat Dec 15, 2012 11:46 pm
Innovate LC1
Greddy boost, oil pressure, and EGT gauge.
92 240sx RB25DET
07 R6
12 Mazda 2-all around beater
