Is there anyway to fix a maf?
rojomojo
Post by rojomojo » Sun Mar 03, 2013 3:07 pm
I was driving and my car just decided to die. So I pulled over and check fuel, plug blah blah. Then I checked my maf, and the car idles without the maf. The i put a multimeter to it and it reads 2.7 volts with the car off, and 3.7 volts with the car idling. Soo is there anyway to fix this?
I cleaned it with maf cleaner.
Regards
Rojo
Post by airman » Sun Mar 03, 2013 8:52 pm
Likely it has croaked - there is circuitry inside of it and it's likely that the board has gone bad. Not sure how to repair that.
R34SR
Post by R34SR » Tue Mar 05, 2013 11:54 am
throw it away, go map.
MEGASQUIRT 2 PNP
AEM IGN1A COILS
HOLSET HX35 .63 AR TURBO
Five-O 750cc INJECTORS
OBX T3 Manifold
ISIS FMIC
CC WHITEBUNNY 6 PUCK CLUTCH
Mazworx z32 tranny swap
CTS V CALIPERS
STANCE LX+ Coilovers
J30 LSD
AME FS01 WHEELS 18X9 +25
FEDERAL 595SS 245/40/18
Post by airman » Tue Mar 05, 2013 1:29 pm
R34SR wrote:throw it away, go map.
^ Easier said than done - to the OP: going to a MAP would require a standalone ECU like Megasquirt, AEM, Haltech, etc which can be costly.
2.7v idle is a bad MAF. It will need to be replaced with a good one - sorry for the bad news!
R34SR
Post by R34SR » Tue Mar 05, 2013 5:07 pm
Yea I know, I god fedup with mafs, even reman ones would eventually die on me, just said eff it and got ms2 pnp, not sayin its feasable for everyone tho
MEGASQUIRT 2 PNP
AEM IGN1A COILS
OBX T3 Manifold
ISIS FMIC
CTS V CALIPERS
J30 LSD
Post by Walperstyle » Tue Mar 05, 2013 9:27 pm
Well if you are going stand alone like motec run both lol
Post by supakat » Tue Mar 05, 2013 9:49 pm
You can run both with MS but it does not make sense quite honestly especially when I am planning on throwing 25psi into my motor shortly. The MAF would blow its hat off. But I did epoxy my n62 and it held with 20psi just fine.
dj_smooth
Post by dj_smooth » Wed Mar 06, 2013 8:33 am
On my z32 maf, my circuit card fried. I followed the tracks on the board and soldered a jumper wire between the 2 pOints. The jumper is not shownin the pictures. Then use A consult to check your voltage. Also ohm out. Around 1volt should be idle.
Post by shift_down » Wed Mar 06, 2013 8:42 am
Hey you know that circular mesh type filter in the maf housing? Is that a necessity if theres going to be a filter at the end of the maf? Im trying to cut the maf down a it to make some room, I was thinking of removing the mesh and trimming away at the plastic.
niceguy
Post by niceguy » Mon Mar 11, 2013 11:54 am
I know on my NA '93 Altima, the mesh provides a laminar airflow that helps keep the MAF/readings happy.
I've run a 'hybrid' intake on the car for years with a KN cone filter bolted to a maf adaptor inside the airbox (to reduce heatsoak) but it required removing the mesh.
I finally ditched that setup late last year after finally realizing that it was causing my idle to fluctuate noticeably and car was going rich (after ruling out everything else over a few months and many gallons of unburned gas lol)
That's all I can say since I'm not FI currently....
