Oil feed line And temp/press. sensor mounting options
- Irresistible
Ok so, I'm finishing up piecing my turbo kit, and one of the last things I need is the adapter to be able to hook up a feed line and my oil press/temp sensors.
I was going to order the Nissport adapter that goes where the stock pressure sending unit is, but that is out of stock right now... I'm gonna call them tomorrow and find out if it'll be back in stock somewhat soon, because I want to get my car on the road as soon as possible.
If it's not in stock soon, I was thinking about just ordering the Glow Shift oil sandwich plate... Would that be just as good as the Nissport adapter? I'm afraid of it leaking... so any feedback on that would be good too...
http://www.ebay.com/itm/OIL-FILTER-SAND ... 32&vxp=mtr
I already have all of the other necessary fittings and adapters and line.
Thanks...
From what I read, sandwich plates give unfiltered oil.... which obviously would be bad, can anyone confirm?
Thanks...
You can just pull the plug out of the stock filter housing, it gets filtered oil, its 1/8bspt thread
If you get an adapter it should have filtered and unfiltered ports, you just have to look at which way the oil flows through the adapter
You can weld a bung for the oil temp sensor in your oil pan if you havent already welded the return bung on.
Its nice to minimize parts that can leak or break.. either should work, i dont have any experience with the oil filter adapters though
Weird, there isn't a place that really sells the old Tuner Toys/Stealthmode performance style anymore. The closest I could find was this, http://www.ebay.com/itm/SUBARU-IMPREZA- ... 5d3e352cc7
Only bad thing is it's in the UK
Then you could easily drill and tap the other side of the 1/8 NPT out for another 1/8 NPT. Have youre oil feed, oil pressure and oil switch all on it. Then like he ^ said weld a bung onto your oil pan for oil temp. I have mine mounted on the side of the sump where the oil drain is. On the back side of the pan. Might just be easier to use that sandwich plate, I've just never been a fan of those things.
- Kamilitaryman
If you're going to be running a oil pressure gauge, is it unnecessary to run the stock oil pressure sensor. It goes directly to the dummy light in the cluster, bypassing the ECU. Sure having a red light come on helps but that's what the gauge is for as well.jholman05 wrote: Have youre oil feed, oil pressure and oil switch all on it. Then like he ^ said weld a bung onto your oil pan for oil temp.
It's not but my oil pressure gauge is off to the side, why disable something useful if you dont have to?
- Irresistible
Yea I'd like to keep the stock one, partially because I don't want to have to deal with an annoying light, and I don't want to remove the bulb because I'm too lazy to take the cluster out.
Well I shot Nissport an e-mail... hopefully they get back to me soon.
As for that Subaru thing you posted a link to... That's exactly what the Nissport adapter is, but the Nissport adapter has 3 NPT ports instead of just one. Which would be perfect in my case.
Another thing I don't want to do is weld the oil temp sender onto the oil pan, because I have Autometer gauges for now, and I will be upgrading to Defi/Stri/Greddy/Blitz soon.
- emo_tactical9
I have been using one of these: http://store.42draftdesigns.com/VW-Oil- ... p_314.htmljholman05 wrote:Weird, there isn't a place that really sells the old Tuner Toys/Stealthmode performance style anymore. The closest I could find was this, http://www.ebay.com/itm/SUBARU-IMPREZA- ... 5d3e352cc7
- Kamilitaryman
Oh I completely understand. I've been debating what to do with mine. We'll see how ambitious I am once I get the filter relocation kit. Chances are I'll end up ditching mine for simplicity.jholman05 wrote:It's not but my oil pressure gauge is off to the side, why disable something useful if you dont have to?
- Irresistible
That looks like another option, but the threads are 1/8NPT, and the block and stock sender on the KA is 1/8BSPT... And I don't want to mix and match the two because I really don't feel like dealing with leaks later. Do it once, do it right.emo_tactical9 wrote:
- Kamilitaryman
You can re-tap that hole (no pun intended) to your liking. I've removed the plug on my oil filter adapter and re-tapped it with 1/8 NPT. It's too easy not to do it.Irresistible wrote:That looks like another option, but the threads are 1/8NPT, and the block and stock sender on the KA is 1/8BSPT... And I don't want to mix and match the two because I really don't feel like dealing with leaks later. Do it once, do it right.emo_tactical9 wrote:
- Irresistible
I'm thinking the best option is to get the Subaru adapter someone linked about on eBay, and then drilling out and tapping another hole. Then using a tee fitting for the two sensors for the time being until I can afford to relocate my filter and get a cooler and all that stuff.
Anyone on here using an NPT tee fitting?
The T fittings can break, especially with the weight of a pressure sender hanging off of it.
I used the glowshift adapter for a few years, it worked fine. I ran a separate line to the pressure sender, I didn't want the pressure sender to break for the same reason I don't like the T fittings.
First setup. One line is oil feed, other is about 2' and goes to the sending unit.
Now I'm running the Skullworks KA oil block adapter. Oil feed is on one port, stock pressure sender is on the other, and oil temp on the 3rd. Pressure sender is now on my thermostat housing.
- Irresistible
I actually just installed that same glo shift sandwich plate this past weekend and questioned it at first as well. It's a tight fit with the sender attached directly to the sandwich plate, but it fits and so far no leaks. Make sure you use teflon tape on all threads and tighten the ports you're not using.
You may want to get a socket that fits the fastener to help secure the plate. I didn't have one big enough so I had to squeeze a wrench in there and hoped tightening the filter would tighten everything.
Again so far no leaks but I will pick up a socket and tighten it at the next oil change just for peace of mind. Just make sure you don't over tighten it.
