Valve cover paint, what do you guys use?
I want to paint the valve cover black, any tips and tricks, and what paint do you guys prefer ?
- shift_down
If you like black, you should use that truck bedliner spray. I think it'll look legit.
Truck bedliner spray ? never heard of it lol i googled it and it looks legit. EDIT heres what i found
http://www.jegs.com/i/Duplicolor/318/BA ... 4Aod_QwAlQ
Yep, prep work is the most important thing. Make sure it's nice and clean. Sand it well, lay several thin coats and leave ~30 mins between each one.
After paint has cured you can take a flapper wheel and grind off the paint on the raised letters for a nice 2-tone look.
Ive always used regular spray paint what ever color i wanted.As said above prep is what really matters and just don't apply to heavy of a coat at a time to cause runs.
I've painted mine a few times to change it up,solid color is easy just take your time, solid with shaved letters looks good and not much harder.here's my latest took a bit more prep work was only hard part.its just duplicolor paint I had in the garage.silver with blue letters and clear coat.
Powder coat. Any color you want and sand off the. Nissan logo. Super easy to keep clean.
- LigouriRd.
I agree, it really doesnt get that hot. The first time around I used high temp engine paint and I found it to be really brittle, chipped very easy. The second time around I used appliance epoxy, it has been very durable and is resistant to most solvents.Freise wrote:The valve cover doesn't get nearly as hot as, say, the head or block and can be painted with pretty much any type of paint.
"There is no such thing as too much boost. You could have too little rod, piston, sleeve, head gasket or timing. But never too much boost."
'91 Nissan 240SX
'96 Nissan 240SX KA-T
'05 Grand Cherokee (4x2)
'85 Honda Nighthawk 450SC
'91 Nissan 240SX
My dad and I have started doing our own powder coating. Stuff is pretty easy once you get the hang of it. Durable and looks great.
This is a much brighter gold in person. Florescents don't do it justice. This one is on my car.
Dad's
My DD valve cover.
Dad's
My DD valve cover.
Re: Valve cover paint, what do you guys use?
VHT makes really good products. Just make sure you find some kind of paint shop nearby so they can bake it properly. Most shops won't charge you much to put it in w/ a full car or something.
I used vht caliper paint for mine.
We also use the eastwood kit and eastwood powders mostly. I think my dad started ordering from another place for powder. This is more of his side project than mine to be honest with ya.
- S14wayz
nice they look really good. Definatly going to get onejholman05 wrote:We also use the eastwood kit and eastwood powders mostly. I think my dad started ordering from another place for powder. This is more of his side project than mine to be honest with ya.
its actually painted i love it, i baked it myself lol barely caused any fumes at all =)
Silver one looks sik!! Great job bro..
Where is the SOHC love! Haha!
Saving KA24's... One at a time...
i just use cheap engine enamel paint from vato zone
and throw in a sparkle clear coat spray i get from lowes
its not that obnoxiously sparkly unless the sun hits it. if its in the shade you will barely see any rainbow sparkles
vato zone haha, looks good, doesnt look like most of the crap jobs i have seen. is there a specific name brand you used for the clear??
