oil light came on this morning
cham
Post by cham » Mon Jul 15, 2013 5:41 am
I got oil so where do I start? I'll probably replace psi switch,sending unit and pump. But the thing is, no local store carries the pump or sendind unit. So where's the best place to get these parts? Or should I just let a shop check over everthing first?
cham
Re: oil light came on this morning
Post by cham » Mon Jul 15, 2013 9:23 am
oil sending unit/ pressure sensor...same thing.Im gonna try this first
Grant
Post by Grant » Mon Jul 15, 2013 9:39 am
cham wrote:I got oil so where do I start? I'll probably replace psi switch,sending unit and pump. But the thing is, no local store carries the pump or sendind unit. So where's the best place to get these parts? Or should I just let a shop check over everthing first?
9/10 it will be your oil sending unit
