New wiseco HD pistons?
jaysol92
Post by jaysol92 »
Anybody know when Wiseco is planning on releasing those puppies? cant seem to find any info and im hoping its before black friday/cyber monday ;)
smbonn2005
Re: New wiseco HD pistons?
Post by smbonn2005 »
Already talked to a buddy that works for Wiseco. They aren't coming out until May/June of 2014. No word on pricing yet. Supposedly thicker skirts, thicker wristpins, lighter, and able to support 1600 hp. Off the shelf KA pistons from them are rated to 1200 hp though so I really don't see much of a need for them unless you are shooting for 1000+ HP like me and a few other guys are.
NateDogg
Post by NateDogg »
I'll have a set next week and will post pics.
'91 S13
Built, balanced KA-T
smbonn2005
Nate, how are you getting a set of HD's for the KA when they aren't released yet?
NateDogg
Post by NateDogg »
Skirts collapsed on their off-the-shelf units so I asked if they could make some HDs.
New pistons have a strutted design for more strength in the skirt area and are about 50g heavier.
See pic.
'91 S13
jaysol92
Post by jaysol92 »
woahhhh :) whats the compression on those??
NateDogg
Post by NateDogg »
jaysol92 wrote:woahhhh :) whats the compression on those??
9.
'91 S13
smbonn2005
Can we get some pictures of underneath etc? Gunna have to bi*ch at my contact at Wiseco that they were saying these were a year out.... How much did they cost you?? Rumor about the bigger wrist pin true?
EDIT: At what HP/TQ did you collapse the skirts on the basic ones?
NateDogg
Post by NateDogg »
I'm not going to give away all of Wiseco's R&D on a message board, especially after they were kind enough to work with me on this set of (custom) HD pistons and develop them for the KA when nobody else is. Look at the pic closely you can see the difference and the 'strutted' design. Maybe they are altering the design for mass production and that's why it's taking so long.
Pins are the HD tool steel units #S721
Not sure what caused the piston skirts to collapse but I was running 450-500whp. It was probably my fault as I unknowingly switched off the meth injection a couple times. Surprised I didn't do more damage, to be honest.
'91 S13
ZERTARACING
Post by ZERTARACING »
Damn and I was thinking of running JE pistons.... wonder how much these will cost.
Building my S-chassis in my garage, piece by piece.
NateDogg
Post by NateDogg »
Check out the evo HD pistons for an estimate.
'91 S13
kacam24det
Post by kacam24det »
these are beefy curious to see the rings
Cam
ZERTARACING
NateDogg wrote:Check out the evo HD pistons for an estimate.
Thanks will do!
NateDogg
Post by NateDogg »
kacam24det wrote:these are beefy curious to see the rings
The rings are the standard XX design.
Here's a pic of the coatings I got put on at PolyDyn.
HS Gold crowns and DL on skirts and bearings.
'91 S13
drunknmunky
Post by drunknmunky »
Interesting. I like the reduced skirt area design. Duno what that groove is between compression ring 1 and ring 2.
I wonder if this will heat up much more than the older design/cp/etc.
Is this just the one that you designed with them or is this the one that they'll full out manufacture?
NateDogg
Post by NateDogg »
I assume this design will be what Wiseco makes in the future...but you know how assumptions go.
'91 S13
drunknmunky
What's the purpose of the groove in between compression ring 1 and 2?
I tried to look it up online and it seems more prominent with custom pistons than base level aftermarket manufactured ones?
Kisor
Post by Kisor »
The groove is supposed to keep the second ring from buffeting. It leaves a little volume for blow by past the top ring to accumulate reducing the pressure on the second sealing ring.
They started incorporating it prob 10+ years ago on pistons, (at least that's when I started seeing it).
drunknmunky
interesting. and it looks as if there is more material between the combustion surface and the positioning of the 1st ring.
appreciate the noticeable upgrades. curious as to how it will perform.
RealStreet
Post by RealStreet »
Wiseco is now adding their Armor Plating to their KA24DE pistons as a factory standard. The plating is permanent and added to their metal matrix to help stiffen the dome. It's added to the ring grooves and wrist pin grooves as well. If you want a custom piston as pictured above, they can be ordered.
Sales, Installations, Dyno, Fabrication, Motor Builds
Visit us at our new location!
850 N US HWY 17-92
Longwood, FL 32750
jaysol92
Post by jaysol92 »
when the time comes, im going wiseco
