adamky wrote:I still want someone to make me a billet fuel tank cap. 2FAS240 on here made one and I've wanted one ever since.
Edit: viewtopic.php?p=509577#p509577
I second this guy ^^^^ Billet fuel tank cap
I could be wrong, but it sounds like one of those "hey i have access to a machine shop/Equipment and can possibly make parts for KA's" threads that pop up on this forum, and zilvia once or twice a year. They almost NEVER bear any fruit. Only company that has come thru is Tomei with their recent developments for the KA engine, and RS-Enthalpy with his anti-stall adapter for people running the Z32 AFM on a SR/KA. Not too many people can shoulder the development and machining costs to support a large community.ka240de wrote:updates ?
will mess around with drawing one up later, will have to see if i can find a intake flange cad drawing somewhere or just scan the stock manifold. would probably need to be 1/4-3/8" thick to have enough meat for those an threadssil-coupe wrote:Mmmm, o-ringed flanges would be sooo nice to have! That fitting looks very sweet!
I'm a little confused, you mean a gasket like this but in aluminum?beercandrifter wrote:on that note of a spacer between the intake/head, i wonder why no one has made an aluminum spacer (replacing the gasket in the process) and just using a barbed fitting for the radiator outlet, something like: http://www.summitracing.com/parts/mez-wn0031b/overview/
could swap out the regular gasket that is always a special order item (at least is here) and replace with orings to seal the head to the adapter
but with a 20 AN threaded port for radiator filler neck?cleantune wrote:I'm a little confused, you mean a gasket like this but in aluminum?beercandrifter wrote:on that note of a spacer between the intake/head, i wonder why no one has made an aluminum spacer (replacing the gasket in the process) and just using a barbed fitting for the radiator outlet, something like: http://www.summitracing.com/parts/mez-wn0031b/overview/
http://www.frsport.com/Circuit-Sports-T ... _8141.html
