my numbers
my numbers
Ok guys I got everything I need and ready to boost the car. I filled out a information form for Rs-enthalpy. One question was engine compression. My bottom end is built with arias 8:8:1 or 8:8 something, built 8 years ago..bored over .20, KA sportsman rods, Clevite bearings The car has 45,000 miles on it Na. My numbers was 145 across all 4 cylinders. Is this right for these lower compression pistons? Everything including the head was stripped down and hot tanked. New valve seals and 3 angle valve job. All Arp hard wear including main studs. so they done a line bore. What do you guys think. I called HRT and I'm thinking about having the engine gone through before I boost it. The motor runs fine and strong. Just don't know about these numbers
Re: my numbers
I just saw online that a wet test gives better results. I may try that
Re: my numbers
I've read lower compresson pistons = low compression results.
My stock 150k mile KA was ~150 across the board and I've been boosting a modest 11 psi for about 8k miles.
Hope that helps.
Hope that helps.
KA-T / 50 trim / JGS manifold / DW550cc / Z32 maf / Q-Garage tune / 12psi
Philippians 4:6 Don’t worry about anything; instead, pray about everything. Tell God what you need, and thank him for all he has done.
Re: my numbers
That helps. Just wondered because I search and found plenty others with higher numbers..Thanks
Re: my numbers
That's a little on the low side, but not bad. What cams are you running? S13, S14, aftermarket, etc.?
Re: my numbers
S14 I suppose. The shop suppied the core 8 years ago. The car is an s14 model. Since all 4 cylinders are exactly the same, would would be the problem?
Re: my numbers
Cams and cam timing both affect your compression numbers quite a bit. If you're running stock S14 cams (232/232), then those compression numbers seem low to me.
Re: my numbers
I can have the timing checked. When I got the timing done it was checked twice with the gun. I've advanced it a lot with the distributor until I heard no pinging. Been like that for a long time. Don't know if that affects it any. I still haven't done the wet test. But tell you what, the car runs, fires and idles like a champ
Re: my numbers
I was referring to cam timing, not ignition timing.
Re: my numbers
Ok I'll get that checked. Thanks.
Re: my numbers
Just figured out what you was saying. The shop lined up then chain marks and holes I'm sure. This guy does this for a living. But anyone can make mistake. I'll still get it checked
Re: my numbers
Was I supposed to unplug my injectors? Would that cause lower numbers?
Re: my numbers with injectors unpluged
160,160,155,155.....I'm worndering what's up with 3 and 4
Re: my numbers
5 psi fluctuation is nothing to worry about. Numbers seem consistent.
Re: my numbers
Ok cool. Ready to get my tune and fire it up. I'm getting a dual tune With e85 and 93 since my town has both. I got 1100cc fic injectors pushed by a stealth 340 pump. I'm hoping to get 350 or so on this set up. I'm gonna upgrade this winter and shoot for 450-500hp
Re: my numbers
So many things affect the compression numbers. Really just make sure they are consistent.
When I first got my car it had a huge 800 CCA battery in it... gave 195psi compression stock...
