Hello just looking for some compiled opinions on my subframe swap and tire size options not very good with tire talk yet..
My car has a 91 hicas s13 subframe .
I have an s13 non hicas subframe, and a guy wanting to sell me an s14 subframe for 300$.
What i was thinking not only save money but that aside the shorter wheelbase should let me get a slightly wider tire in there wouldnt it ? I plan on using a 26 inch street friendly radial of some sort on refinnished stock rims Im going for a sleeper look and dont want to draw attention.
Whats the fattest tire to fit stock rims?
another subframe thread
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
Re: another subframe thread
The s14 subframe requires some "offset" bushings that SPL parts sells and you will need to swap the s14 differential cover to your s13 differential; s14 camber arms are also recommended since the s14 subframe is wider.
If you already have an s13 non-hicas subframe though, why not just put that on for now?
Depends on what you want to do with the car. Personally I like the S14 subframe for the better suspension geometry due to the change in pick-up points. But you also have to weigh in price/performance increase as well. Not only is the subframe gunna cost you money, but the offset bushings to mount it in a s14 (SPL or GkTech), the S14 camber arms are also needed, as well as any misc stuff you break/replace along the way.
As for fitting a wider tire, the 10mm wider track isn't going to make THAT big of a difference either way unless this is a track dedicated car, which even then I don't think your allowed to do subframe swaps etc in most classes.
An S14 subframe for $300 is a ridiculous price just fyi. Had picked up mine with 0 rust and brand new bushings for $100
Thanks guys and the cars is to be a restored street car complete sleeper on the exterior. And when its not on the street itl be at the strip . Thanks for the pricing info, i am in canada, but yeah i guess im looking at an extra 500$ for little gains
Your welcome!! Let us know what you decide! =)
Just needed some advice from my elders! Ill swap in my s13 non hicas from my other 240
