Boostane octane booster ( It works!! )
- R34SR
Anyone heard of this stuff? anyone try it out ? based on my calculations and i confirmed this with their tech, 1 qt can treat 14 gals of 93 octane and turn it into 102 octane...i bought a quart and im gonna see if i can " cure " my overboosting issue with more timing instead of less
$25 a pop.....yeesh.
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
Mazworx z32 tranny swap
CTS V CALIPERS
STANCE LX+ Coilovers
J30 LSD
AME FS01 WHEELS 18X9 +25
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
Re: Boostane octane booster
you can buy like 5 gallons of unleaded 104 for about 75$ special ordered from most any gas station if thats of interest to you.
- R34SR
I live in NYC...the nearest high octane gas is in New Jersey....like an hour out.
Why would I wanna pay $75 for 5 gals of gas?
If this product really can do what it claims.. I'll end up spending $3.99 x 15 gals = $59.85 for 93 octane then one $25 can puts me over 100 octane on a full tank totaling $85.
Guess we'll see if it works or not.
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
its not AT the pump. its special ordered in 5 gal cans so im sure about ANY mobil can get it.
im just contributing info relevant to octane that is proven. should your little experiment not work out, it may become an option.
sounds sweet, i hope it works, but im not holding my breath. if it was miracle juice youd see a lot more of it being used. (E85 asside) why is it that guys pay 12$ a gallon to make well north of 500 if you can just go buy this liquefied fairy dust?
im not really sure what overboosting has to do with octane though.
if the **** works, i'll run it at events and not even touch my tune. thats what got me looking into the cans... wanted to bump the octane for nothing other than safety at events.
Local tuner just started carrying the stuff. Might try it out myself!
- R34SR
Well if I get a chance to try out this weekend I'll let you guys know how it goes....right now my setup holds 12 psi but creeps up to 16....by the time it reaches 16 psi the power falls hard due to the fact that I have to pull timing out to prevent knock....therefore if this product allows me to maintain the timing...I should see nice gains up top.
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
- R34SR
Boostane octane booster (It works !!)
well guys i finally got a chance to test it out this weekend, filled up with 93 and emptied one can into the tank , so id say about one can on 17 gals which theoretically put me at around 100-102 octane. Drove around a bit to try and slosh it around and mix well into the tank.
Proceeded to tune.....i gained over 3 degrees in pretty much every area of my map! and i still am yet to hear knock. Its truly is an amazing product....i decided not to push it even further as my tuning area started to get some traffic, but i can tell you this stuff really works, unfortunately virtual dyno was giving me some issues saying i was making the same power....but i definitely picked up a good amount of power up top... before i would induce knock very easily with a degree here or there, now its like i can just keep giving it timing and shes fine....pulls hard all the way to the top. I hope i can get virtual dyno to work so i can post up some results.
But as of right now im looking into buying the 5 gallon pail for $350....being that i drive my 240 once a week if so much, should work out well for me.
i highly recommend you guys just try it once and give your opinion, $25 is cheap for something that can possibly save your motor on a track day.
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
Re: Boostane octane booster ( It works!! )
Thats great, how are you detecting knock?
Cosmetic Head Gasket
Eagle Rods
Stock flywheel
Spec Stage 3+ Clutch
ARP'ed Everything
Clevite Bearings
SARD 850cc Injectors
Eagle Rods
Stock flywheel
ARP'ed Everything
Clevite Bearings
- R34SR
Det cans,it's the only way I trust.
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
ah, through your speakers?
Eagle Rods
Stock flywheel
ARP'ed Everything
Clevite Bearings
Eagle Rods
Stock flywheel
ARP'ed Everything
Clevite Bearings
- R34SR
No...the old fashioned way...copper pipe flattened and bolted to engine block connected with 5/8 vacuum tubing to ear muffs.
Nothings is simpler or better.....saved my motor many times
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AWESOME!!!! are you finding it for 25$ shipped? i see ebay its 32 shipped.
I think you can just buy some Toluene at the hardware store and do exactly the same thing. It will almost definitely be cheaper. Just make sure to keep it off your paint.
- R34SR
I won't doubt what you're saying about toluene, xylene etc.. but my concern is also consistency ...every batch of this stuff is tested...for consistency , it has a pretty decent following and considering how little I drive,the car....it's worth it for me. I bought a 6 pack for about $149 shipped which works out to $25 per qt. The bigger you buy the cheaper it is...when I finish this I'll buy 5 gals which when shipped works out to $20 per qt.
I'm running 15* of timing now at 19 psi knock free..that's 34* total...try that on 93!
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
- R34SR
Virtual Dyno as promised!
Just posted this in my dyno thread, clearly this stuff works, im not doubting the same results can be had with toluene and marvel
mystery oil but for now im happy paying $25 a quart since i hardly drive my car.
This is with a mixture that results in 100-103 octane, and 19psi boost.
enjoy!
enjoy!
MEGASQUIRT 2 PNP
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
ISIS FMIC
CTS V CALIPERS
J30 LSD
