http://dsm.fidke.com/articles/diy-bead- ... -weld.aspx
Cheap alternative for intercooler bead
- S14wayz
Re: Cheap alternative for intercooler bead
this is creative but defiantly a bad idea, I couldn't imagine that holding under operating conditions with boost
Just thought it be interesting and maybe worth sharing.
A bead rolling tool cam be made out of a set of vice grips, exhaust clamp and a large washer. If you search there are multiple examples online on how to. Cost me less than 20$ and worked perfect
I'm new so take it easy... But if it's easy take it twice
Here's one I made a few years ago using an old ball bearing race.
NismotronicSA Tuning Package/Powered by TunerCodeSA
Speed-Density Tuning for Nissans
NO!!
OnTheChip wrote:Here's one I made a few years ago using an old ball bearing race.
YES!!
Yeah, definitely make yourself a bead roller. Inexpensive, unlimited, reliable results With steel piping I'd settle for some 6-8 small weld beads around the perimeter.
- S14wayz
those beads look great onthechip.. way better then the ones those guys make with the vice grips and exhaust clamps..
- nissanfanatic
I have simply bent the tube with pliers and it seemed to work in a pinch.
Though, I used a welder to weld a small bead onto pipes long term.
Otherwise, truck radiator hose for couplers and/or hairspray are other common fixes.
