Who here doesn't run a bov?
Wingu513
Post by Wingu513 » Sun Oct 19, 2014 12:47 am
Just wondering what people think of it.
Re: Who here doesn't run a bov?
Post by schmauster920 » Sun Oct 19, 2014 4:00 pm
My opinion = Extra wear on turbo for no reason. How much? I dont have a clue, air reverting back through it cant be good.
It does sound cool :)
gtrpryde
Post by gtrpryde » Thu Oct 23, 2014 4:42 pm
I mean, it sounds cool and all, and if I had the coin to replace the turbo every couple of months I'd probably do it...
Lol. Jk. Bad idea. Only diesel guys run no BOVs. I'm sure some other guys do it too, doesn't make it a good idea.
KA-T / 50 trim / JGS manifold / DW550cc / Z32 maf / Q-Garage tune / 12psi
Philippians 4:6 Don’t worry about anything; instead, pray about everything. Tell God what you need, and thank him for all he has done.
SoundEfx
Post by SoundEfx » Fri Oct 24, 2014 3:48 pm
Only ballers don't run a bov.
Image << Yuh dun know!!
TrackStarGT
Post by TrackStarGT » Fri Oct 24, 2014 7:48 pm
I have run across a few threads were guys have run without a bov. There are benefits to having one, but the theory that it is ok is not widely excepted, my thoughts are if you run an anti surge it would help the situation. Also, when the air surges backwards against the compressor the compressor is under no load other than it's own inertia which isn't much, this only loads the thrust surface that doesn't usually see load, only when surging. I don't think its that bad for the turbo,
S14wayz
Post by S14wayz » Tue Oct 28, 2014 9:30 pm
idk why you wouldn't run a BOV. All that extra pressure from the turbo needs to go somewhere once the throttle closes and you'll just wear the turbo much quicker running without one. If you cant afford a real BOV you can use one of those bosch diverters and just recirculate it back into the system. I ran one of those on my s13 for years
My S14 Build Thread
viewtopic.php?f=40&t=59534
