open dump
cham
open dump
Post by cham » Sun Oct 26, 2014 9:45 pm
I've always ran open dump on my wastegate since day one. It never went boom in between shifts. It only done it after boosting and letting the car cost. I've noticed after about a month of driving, it no longer goes boom. Maybe it's because I'm not running off of the waste gate spring. I'm running a mbc. What do you guys think?
Re: open dump
Post by schmauster920 » Tue Oct 28, 2014 12:40 pm
Check that your TPS isnt loose, voltage is correct at idle and reset the ecu. It will think the throttle isnt closed and still be adding fuel.
cham
Re: open dump
Post by cham » Tue Oct 28, 2014 1:00 pm
So does it suppose to go boom and if so when? The car idles and runs fine. It Holds boost like it's suppose to. When I first started on e85 I did have some 93 left in the tank. Do you think the mixture is what was making the wg go boom and shoot flames?
Re: open dump
Post by schmauster920 » Tue Oct 28, 2014 3:41 pm
It shouldnt backfire normally. The TPS adjustment should take care of it
cham
Re: open dump
Post by cham » Tue Oct 28, 2014 5:46 pm
I'm good then. I fooled around with the tps when i adjusted the idle screw. The wg doesn't boom anymore. I was just wondering was it suppose to. I hear how everyone says open dump sounds so good, I was wondering what the hell they was talking about. Must be talking about that screaming sound when you hit the set boost and it regulates until you let out. Actually i hate it. It drowns out the spool sound of my Lil turbo
Re: open dump
Post by schmauster920 » Tue Oct 28, 2014 8:25 pm
I think its a fun sound in an otherwise quiet car but its hard to hear detonation over it, so i wont ever be open dump unless i have a really nice EMS and knock detection, and a lot of faith in it
nissanfanatic
Re: open dump
Post by nissanfanatic » Sun Nov 02, 2014 6:14 am
It helps a lot to run a dump tube down under the car.
-Cory
1992 Nissan 240sx KA24DE-Turbo [ GONE ]
1995 Subaru Impreza L AWD [ OK ]
2000 Honda S2000 [ GONE ]
2003 Infiniti G35 Sport Coupe [ GONE ]
1986 Ford F-250 4x4 International IDI Diesel [ GONE ]
2003 Mitsubishi Lancer Evolution [ GONE ]
2004 Subaru WRX Wagon [ GONE ]
2009 Honda Fit Sport [ OK ]
2002 BMW 325i Sedan [ OK ]
Use Linux...
cham
Re: open dump
Post by cham » Sun Nov 02, 2014 6:31 am
It hangs a hair below the steering linkage
nissanfanatic
Re: open dump
Post by nissanfanatic » Sun Nov 02, 2014 6:40 am
Mine fried one of the steering boots.ha
-Cory
Use Linux...
cham
Re: open dump
Post by cham » Sun Nov 02, 2014 6:50 am
I made sure it was below all of that but not low enough the bottom out.
