heater hoses?
heater hoses?
DE track car with no heater, will be using an excessive intake if that matters. is it okay to cap off my heater core lines or is it an absolute must to recirculate? today i cut and welded (one of many i have) the heater core nipple on the block. thought i should ask before running it.
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
Re: heater hoses?
No it isn't necessary
Cosmetic Head Gasket
Eagle Rods
Stock flywheel
Spec Stage 3+ Clutch
ARP'ed Everything
Clevite Bearings
SARD 850cc Injectors
Eagle Rods
Stock flywheel
ARP'ed Everything
Clevite Bearings
Re: heater hoses?
well thanks for the reply. but incase anyone else is ever searching. ill make this topic useful.
here is a diagram of the coolant circuit that speaks for itself.
Re: heater hoses?
You should still keep the large by-pass line, but all the other lines are optional for a racecar.
How do you defog if its raining during your track day?
Re: heater hoses?
When I blocked off the outlet on the block for the heater core and the return that leads to behind the thermostat, I found it impossible to bleed with the custom manifold I run. I had to put the elbow back into the block and connect that to the nipple behind the thermostat.
Your mileage my vary but that is my experience
