They just released this guy:
http://www.gktech.com/index.php/s13-s14 ... -flow.html
Now let's talk fans for a bit:
A while back (a few years here), I read about the importance of the stock cooling fan. Even with a proper e-fan setup, our engines were spiking in temps and when people re-installed the factory clutch fan, the temps would stay in check. Now, I have aquestion is for those with unique cooling setups, such as those that no longer employ the stock radiator shroud. Do you think running the clutch fan would benefit the motor, even if the fan shroud is not there? I'm running an aftermarket, small Honda Civic radiator with an e-fan and I'm curious to see if this fan would benefit my setup.
GKtech is still at it!
- Kamilitaryman
Re: GKtech is still at it!
That's pretty cool (pun intended) that they make that now.Kamilitaryman wrote:Do you think running the clutch fan would benefit the motor, even if the fan shroud is not there? I'm running an aftermarket, small Honda Civic radiator with an e-fan and I'm curious to see if this fan would benefit my setup.
My opinion is that without the shroud, I think it's effectiveness would be greatly diminished. I bet a properly shrouded e-fan setup would do just as good, if not better than that fan without a shroud. And if you are running one of those Civic fans that are about 1/2 the length of the stock KA radiator, I can't imagine it would be an upgrade over your e-fan. When designing effective cooling systems, it's all about the shroud/ducting and being able to force air to only pull from where you need it to.
EDIT: I just saw where you said that you want to use this as an addition to your e-fan setup. That may make a difference by being able to circulate more air around the bay. Hard to say without trying it.
- street_240sx
Gktech made that fan years ago. I run altima fans and have no issues. There are a few sr20 guys here that run mech fan with handmade metal shrouds, they look dope and im sure function just as well. I like efans for space, ease to work on and looks. If they made a heavy duty fan clutch that worked on our cars that would be dope. I never forsee myself going back to mechanical
03 evo8 gsr: stroker 2.3
