turbo oil drain leaking
Anyone of you guys ever had the oil drain leaking at the turbo. I dunno what the hell is going on! ! have tried everything! its just a standard T3 turbo every gasket I've tried leaks. currentley i am using a copper gasket with high temp silicon and it still freaking leaks. I even went as far as taking my flange to work and having the machine shop surface grind it to assure its perfectly flat. still leaking how much damn pressure is coming outta this thing??
suck it!
- hotbox240
Re: turbo oil drain leaking
Ball bearing or journal? What size oil feed line are you running? How is your PCV setup? How big an air filter are you running?
12.43 @ 115.06 - 05/2010
12.28 @ 117.61 - 08/2016
Journal bearing turbo stock datsun 280zx right now i have my actuall pcv valve removed with a straight fitting running to the catch can and the valve cover vent running to the can as well and venting to atmosphere. Just using a cone style air filter with a short elbow. Using MSPNP AIT sensor and map sensor no MAF
suck it!
- flip240
So this is a L28 turbo? Is is the stock drain line?
My setup: KA24DE-T
My setup: KA24DE-T
No im using a 3/4 ID drain all the way to the pan and a -4 feed
suck it!
