Currently have my motor apart and st the machine shop. Below is a list of parts and labor already done. Is there anything else everyone would recommend to do before I start to reassemble it? Building for 600-700hp.
Head:
BC stage 3 cams
BC Valves/TI Dual Springs/Retainers
BC Bronze Valve Guides
ARP sleeved washers for studs
Hot tanked
Decked surface
Machined valves
Machined exhaust guides
Line hone cam surface
Head machined for cam lobe clearance
Machined head stud ports to install ARP sleeved washers
Block:
Wiseco 89.5 Pistons/rings
Manley I Beam Rods
King main/rod bearings
ARP 10mm Head studs
ARP Main Studs
Sleeves
Hot tanked
Decked surface
Cylinders ported and sleeved
Line hone for main studs
Polished crank
O-ring cylinders
Rotating assembly balanced
