no idle switch in haness?
Ok heres a question to stump you guys so there is no idle switch pigtail in my harness does anyone know what this would affect?
Re: no idle switch in haness?
I'm not even sure what an "idle switch" is...?
its the input to the front of your tps NOT the wires going to the tps
Can you post a pic? All the TPS sensors I've dealt with in my car have only had 3 wires going to them, so I'm still not sure what you mean.
My guess is you have an AT TPS but a MT harness. If you are running a manual trans dont worry about it, the ECU uses the TPS signal for idle (<0.52v = TPS closed).
