HowTo: S14 Walbro fuel pump install
SpoolTool
Post by SpoolTool » Sun Nov 09, 2008 12:52 am
Anybody know how to do the wiring? That would be helpful in this thread
SELLING MY FRONT MOUNT, COMPLETE KIT FOR $200 With the BOV
importdude
Post by importdude » Sun Nov 09, 2008 1:14 am
its only 2 wires
use the supplied crimps
SpoolTool
Post by SpoolTool » Mon Nov 10, 2008 6:37 am
importdude wrote:its only 2 wires
I have a walboro installed on my car and theres 4 wires going to a relay. I bought the car with it installed and I was looking for a more simply way to wire it in as it is now hard wired to a switch..
Knowing the number of wires doesn't help much if you don't know where they go :roll:
I'm gonna re-wire mine soon (busy at school) So I'll post how that goes maybe with some pictures if I get it working properly.
EstoMax
Post by EstoMax » Tue Nov 11, 2008 1:22 pm
maybe your car has the walbro 'hard-wired' in. If there is a relay the stock fuel pump power lines might be triggering the relay, which get power straight from the battery to the fuel pump.
Marko
95 s14 kaT
t3/t04e (60 trim), bikirom, groundzero mani/dp, 82 lb AMS FS
94 d21 kaE 4x4 stock
SpoolTool
Post by SpoolTool » Thu Nov 13, 2008 12:03 pm
EstoMax wrote:maybe your car has the walbro 'hard-wired' in. If there is a relay the stock fuel pump power lines might be triggering the relay, which get power straight from the battery to the fuel pump.
Marko
With that being said how is everyone else wiring their units in?
If there are 2 main wires, one for power and ground, where should I splice the power wire so that it gets 12 volts when the key is on?
EstoMax
Post by EstoMax » Tue Nov 18, 2008 3:57 pm
afaik most of us have it wired conventionally.
i don't know what you have there.. take pictures or something before i can advise you further. If you have a relay, then the stock wires coming from the front of the car would power the relay trigger and there would b a wire from the battery (with an inline fuse) going to the relay and another one going to the fuel pump, and from the fuel pump a wire going to ground.
MArko
make a new thread if ur confused, most people dont check stickied threads.
95 s14 kaT
Chay G.
Post by Chay G. » Tue Dec 30, 2008 10:00 am
why not using an inline walbro?
Xren17
Post by Xren17 » Thu Feb 26, 2009 1:03 am
Hey,
Just wanted say thanks for the write up. It made life a bit easier on me.
-Ren
el_mata
Post by el_mata » Sun Mar 15, 2009 9:51 pm
i just did mine... but how is it that the cables from the walbro might cause a spark and explode. I think of it every time I start the car!
Xren17
Post by Xren17 » Mon Mar 16, 2009 7:54 am
Haha. I had the same question but it'll be fine as long as you have the connectors crimped and insulated. The reasoning being that gasoline is a poor conductor therefore a good insulator. This means that current does not travel well through it so there's no worry of a spark unless the power line comes into direct contact to a ground.
-Ren
EstoMax
Post by EstoMax » Sun May 03, 2009 7:40 pm
also keep in mind electricity takes the path of least resistance.. so as long as there is some wire connecting the right wires and their not shorting with each other you won't have any problems.
Marko
95 s14 kaT
godchsr
Post by godchsr » Mon Nov 16, 2009 8:32 am
Excellent write up! I will be doing this very soon! I will try and snap a few pics along the way as well.
shift_s14
Post by shift_s14 » Wed Apr 28, 2010 11:15 am
thanks for this post, it helps a lot
i just remove it yesterday, i just strugle a little bit to insert back because i don't have enough light, but i'll finish by today
meny_
Caveit77777
Post by Caveit77777 » Mon May 10, 2010 9:53 pm
I don't know if I'm really asking this but whats the l/hr difference on the stock pump compared to the walbro 255?
8-bit
Post by 8-bit » Wed Jun 23, 2010 6:46 pm
thanks for the writeup.. I'm glad to hear that the long sock is in my current tank and that I can use it on the walbro. I ended up ordering an S13 pump for my S14 because people don't seem to have S14 stuff and I was starting to get a little wary about not having a sock that goes long enough.
looks easy cheesy like the S13 was (back when i had one).
http://www.areasoundmusic.com
will.yum
Post by will.yum » Thu Jan 27, 2011 1:07 am
Good write up man def helped a couple days ago but was confused on how the pumps brackets were put back in but figured it out quick and smacked myself lol.
I love my fiance and 2 girls goldie and jade =P
coachbag01
coach bags ...
Post by coachbag01 » Wed Mar 30, 2011 4:16 am
Yes - A couple other forums that I frequent do it that way and it works great...
DeatschWerks
Post by DeatschWerks » Fri Aug 19, 2011 9:18 am
Just wanted to let you guys/gals know that this install guide will work for installing our DW301 fuel pump, as well.
project-c2
Post by project-c2 » Sat Feb 25, 2012 7:53 pm
I followed this to the T and when I was done, I turned the key on and it just sounds like the pump is free wheeling. I cranked it and no start. ****. I take it back out and noticed the black and red wires are in the wrong pins. The pump has markings and the black wire was going to the (+) side. FACK. So I recrimp the wires red going to black and red/green going to red. Then it worked. Just a warning to follow the pump markings and not the wire color. Hope this helps people in the future. I did the install with the tank out cause I was swapping then ended up doing it on the car, cause the tank was installed.
YadPwns
Post by YadPwns » Sat Mar 31, 2012 2:51 pm
Awesome write up!! THANK YOU!!! Was a breeze to install my walbro today thanks to this!!
Cheers!!!! :D
yvang07
Post by yvang07 » Sat Feb 16, 2013 12:16 pm
Bookmark'd I know I'm going to be referencing when I do mine also, it's been in storage and I haven't had much time to work on it, but we'll get there eventually.
En Garde!
sm240sx
Re: HowTo: S14 Walbro fuel pump install
Post by sm240sx » Thu Aug 08, 2013 7:17 pm
very useful information!
A drift a day keeps the hondas away.
1998 Deep Fuschia Kouki - DD
dls2200
Post by dls2200 » Tue Oct 22, 2013 12:13 pm
Awesome cant wait to get started on mine!
"OVERNIGHT SHIPPING FROM JAPAN CAN BE EXPENSIVE"
Stock KA24DE 230k
Rebuilt head
Felpro oem headgasket
Arp headstuds
STI 550cc yellow top
t04e .48 50tirm
10lbs
255 pump
tial wastegate
hks bov
Empathy rom tune
Stock clutch
gilbertofeldker
Post by gilbertofeldker » Mon Jan 19, 2015 6:28 pm
Digital products play a dispensable role in our daily life in such a technology developed dramatically world. More and more people want to own a high configuration electronics with a fast operation speed. With development of high technology, it is common to see that there are various kinds of high tech products nowadays,
wanna try wholesale digital camera?Here are best quality for men selling and all of them are of good quality and low price.
