Page 2 of 2
Posted: Mon Feb 25, 2013 10:29 am
by Chris28
You can also use Earl's part number 165056ERL, it converts 5/16" hardline to -6an.
http://www.summitracing.com/parts/ear-165056erl
Posted: Mon Feb 25, 2013 10:52 am
by airman
Nice find Chris. Use a legit tube cutter and there will be no flaring necessary, right?
Posted: Mon Feb 25, 2013 4:55 pm
by kacam24det
sweet write up found the solution i needed was gunna run braided line all the way back to the tank not anymore
Posted: Mon Feb 25, 2013 9:36 pm
by Chris28
airman wrote:Nice find Chris. Use a legit tube cutter and there will be no flaring necessary, right?
Correct. There's a small piece inside the two halves that essentially flares and seals the stock line as you tighten it. I just noticed these are only rated up to 50psi though, not sure how much a regular 37° flare fitting is rated to but you might run into issues if you run over 4 bar fuel pressure.
Posted: Tue Feb 26, 2013 11:15 am
by airman
Hmm 50psi rating would be pushing it - especially if you're boosting 20+ psi.
Regular flare fittings are the same fittings used in hydraulics - aka 3000+ psi lol. Of course at that point the hose limits that.
Hmm, also the 50 psi rating might be a safety factor of 2 or more. Might still be okay but I would want to verify with the manufacturer. There could be a similar option by another vendor that can handle the pressure comfortably.
Posted: Tue Feb 26, 2013 11:37 am
by Chris28
Yeah, I'm sure there's a factor of safety in the 50 psi limit, I wonder what it is. If I get bored I might give Earl's a call and see why the rating is so low and if it's ok to be over 50psi as long as it's not continuous.
Posted: Sun Mar 03, 2013 7:52 am
by Jmoore124
That is a compression style fitting. The exact fitting the OP suggested against using in his post. You can go that route, but I would never trust a compression fitting to my main fuel line feed.
Posted: Mon Mar 04, 2013 8:20 pm
by Chris28
Yeah, after reading about compression fittings I'm going to return them to Summit and go with the flare fittings.
Re: How to *properly* run AN fittings with stock fuel lines
Posted: Tue Jul 23, 2013 8:47 am
by wtfarpus
awesome write up man thanks alot.
Posted: Tue Jul 30, 2013 10:35 pm
by wtfarpus
thanks alot, was actually going to do this, great write up.
Posted: Wed Oct 09, 2013 11:27 am
by Rb26kouki
Great write up very helpful
Posted: Tue Nov 05, 2013 7:21 pm
by ZERTARACING
Will Be doing this when I go KA-T thats for sure. Nice write-up.
Posted: Thu Mar 20, 2014 1:12 pm
by JoeDirte
This makes chase bays kit look sad...
Posted: Fri Jun 27, 2014 6:23 am
by airman
The more I read about the compression/slip on fittings, the more I'm scared of them!
The last thing you want is atomized fuel spraying out in a hot engine bay from a high pressure leak. No thanks. I'll do it the right way and use flared tubing with the tube nut. No way I'm risking my engine bay at just the minimum to save some effort up front!
