OBD2 intake manifold picture
plaza80
Post by plaza80 » Sat Nov 07, 2009 10:36 am
Does anyone have a picture of their OBD2 intake manifold or knows my question. I have a guy installing my motor for me but he says i'm missing a sensor on intake manifold. It is supposed to be located right on the #3 runner of the top portion of the manifold. I can clearly see that there are two threaded holes there that something can be screwed down to.
The thing is I bought a second intake manifold and it still doesn't have this sensor. So my question is does it really have a sensor there? There is a plug on the engine harness that we cannot find where it is supposed to plug into and it seems like it directs it right to the spot where the missing sensor is. My car cannot idle at the moment and runs really rough. All other sensors and vaccum lines are plugged but that.
I'll try to post a pic but my dam camera sucks right now.
plaza80
Post by plaza80 » Sat Nov 07, 2009 10:51 am
The two holes on top of the third runner.
boker240
Post by boker240 » Sat Nov 07, 2009 12:45 pm
looks like fuel line mounting points.
currently n/a.
katinlv
Post by katinlv » Sat Nov 07, 2009 12:49 pm
If you visit the page you can click on the part numbers and find out what they are.
http://www.courtesyparts.com/images/s14/s14_223-3.gif
KFLS14
Post by KFLS14 » Sat Nov 07, 2009 1:04 pm
yep there is a sensor its green.. map manifold absolute pressure sensor. obd2 96-98 had them. extra emissions deal. IMy friend might have a spare actually, we did ka swap reused s13 intake manifold on s14 block.
Pic of stock wiring etc..
240-kid
Post by 240-kid » Sat Nov 07, 2009 1:06 pm
Looks like It's for the Hard lines...
plaza80
Post by plaza80 » Sat Nov 07, 2009 1:23 pm
wow guys thanks for the fast response. How important is this sensor anyways? If I don't have it will it affect my idle or fuel delivery???
I got a 1998 all obd2 btw.
240-kid
Post by 240-kid » Sat Nov 07, 2009 1:37 pm
It'll trim the Fuel according to Elevation...
plaza80
Post by plaza80 » Sat Nov 07, 2009 3:18 pm
hummm if that is all then I'm not sure that is why my car cannot idle well at all. However by taking care of this issue I can eliminate some variables. I really hope this is why i'm having issues with the car.
240tuned91
Post by 240tuned91 » Sat Nov 07, 2009 5:15 pm
rip every sensor off ur intake lol.
keytops
Post by keytops » Sat Nov 07, 2009 11:26 pm
240tuned91 wrote:rip every sensor off ur intake lol.
yea but then they will have a cel on all the time. Put a resistor! no more cel, I hate that light being on like my car is broken or something lol.
oaznbeasto
Post by oaznbeasto » Mon Nov 09, 2009 11:13 pm
pull the bulb out! problem solved, remove all the emission crap makes life easier believe me :D, and cleans the engine bay up
The check light is like that annoying kid, back when you were in school, the one you just wanted to slap! :D
