So do i need an adjustable FPR or not?
- wannaboost?
Ok i cannot find a clear answer to this question, I have ran 2 previous ka-t setups fine with the stock fpr but i had some more concern for my latest build.
sohc-t
t3/t4
740cc
walbro
10psi
300whp ish
jwt ect
sohc-t
t3/t4
740cc
walbro
10psi
300whp ish
jwt ect
Build.Boost.Break.Repeat.
I want one... and a pressure gauge.
FSM> http://www.240edge.com/manuals/usdm-cars.html <FSM
"INVOLUNTARY HELLAFLUSH"
-Walperstyle
I want it cheap and fast. I can fix anything.
-Walperstyle
- metalshark
I got a friend with a red top SR20 that put in a walbro 255lph and he needed an adjustable FPR because the walbro was making him run rich, but I'm running a Walbro 190lph on stock FRP just fine...
I would say Its best to be on the safe side, with an adjustable one that has a funny looking gauge on it, and a ridiculous color
yeah they should come with an adapter plate with the a nipple on it to connect the hose...
i ran my first ka-t setup on stock fpr, but the one im running has an adjustable, i think a lot of it has to due with what method your using for tuning.. on my first setup i was using a calum so i could adjust for the abundance of fuel, my setup now is using an enthalpy tune with no piggy back so i needed a way to cut fuel
built motor, custom bottom mount, t67, midmount i/c, blowthru z32, tial w/g, hks ssqv, d/w 740's, l/w flywheel, comp 4 puck, b&m shifter, no p/s, no a/c, no emissions
<b>Under Construction</b>
spun a rod bearing
be back in no time
spun a rod bearing
be back in no time
True, but as long as you have a tunable ECU, it's not a big deal. I'm still running the stocker, with no intention to upgrade. If someone is running a pre-tuned ECU, it would be wise to get an adjustable one.fos240 wrote:for the record, the stock fpr cant keep up with a walboro or z32 pump. no you don't "have" to get an adjustable, but the fuel pressure will be elevated by 10 psi.
