So do i need an adjustable FPR or not?
wannaboost?
Post by wannaboost? »
Ok i cannot find a clear answer to this question, I have ran 2 previous ka-t setups fine with the stock fpr but i had some more concern for my latest build.
sohc-t
t3/t4
740cc
walbro
10psi
300whp ish
jwt ect
Build.Boost.Break.Repeat.
Post by TinyT »
NEED? most certainly not
ATLspeed
Post by ATLspeed »
nopes
- KA24DE = 14.8
- KA24DE-T25 (7psi) = 13.1
- KA24DE-T28 (12psi) = 12.9 (traction issues)
- KA24DE-T HE351 (20psi) = ??.??
- 2JZ HX40 (18psi) = LOL
~Set Up~
2jzgte, built head, blah blah blah
iceman1357
Post by iceman1357 »
I want one... and a pressure gauge.
FSM> http://www.240edge.com/manuals/usdm-cars.html <FSM
"INVOLUNTARY HELLAFLUSH"
-Walperstyle
I want it cheap and fast. I can fix anything.
tom550
Post by tom550 »
iceman1357 wrote:I want one... and a pressure gauge.
then get one. its not really needed but if you want it then why not.
fos240
Post by fos240 »
for the record, the stock fpr cant keep up with a walboro or z32 pump. no you don't "have" to get an adjustable, but the fuel pressure will be elevated by 10 psi.
tom550
Post by tom550 »
actually some poeple just have bad luck with the stock fpr for some reason. they can handle walbro.
metalshark
Post by metalshark »
I got a friend with a red top SR20 that put in a walbro 255lph and he needed an adjustable FPR because the walbro was making him run rich, but I'm running a Walbro 190lph on stock FRP just fine...
I would say Its best to be on the safe side, with an adjustable one that has a funny looking gauge on it, and a ridiculous color :)
jonathanprem
Post by jonathanprem »
Is it easy to install fpr on stock rail?
95 240sx- soon to be KA-T
jwrose
Post by jwrose »
yeah they should come with an adapter plate with the a nipple on it to connect the hose...
i ran my first ka-t setup on stock fpr, but the one im running has an adjustable, i think a lot of it has to due with what method your using for tuning.. on my first setup i was using a calum so i could adjust for the abundance of fuel, my setup now is using an enthalpy tune with no piggy back so i needed a way to cut fuel
<b>Under Construction</b>
spun a rod bearing
be back in no time
jonathanprem
I got question about fPR. I just bought Fuel lab FPR that i will be using with the stock fuel rail but it didn't come with a fitting for the rail. Do anyone know what kinda fitting will fit stock fuel rail.
Rail is 95 ka24de, 550cc deautch work injectors
Post by adamky »
fos240 wrote:for the record, the stock fpr cant keep up with a walboro or z32 pump. no you don't "have" to get an adjustable, but the fuel pressure will be elevated by 10 psi.
True, but as long as you have a tunable ECU, it's not a big deal. I'm still running the stocker, with no intention to upgrade. If someone is running a pre-tuned ECU, it would be wise to get an adjustable one.
