stock ka-t running pig pig rich
- 91_ka24de
Stock ka oem built stock inj fuel pump adj fuel pressure regulator at like 31psi running. And fouling the plugs in seconds. Any idea? Wideband saying 10.0 when revving jumps to 11-12. Revs freely. Havnt drove it. And I'm not sure what the psi is spoused to be at while running with vaccume.
"we never have money to do it right,but we always find money to do it twice"
"Money isn't really much of an issue. Only the time it takes to make it." -ILuvS13s
Hatchback,ISIS/HKS Hyper D-Max coilovers, Work Euroline DH fronts 18x8 Rears 18x9 205/40's,Wiseco Pistons,Eagle Rods,deatch work 740cc injectors 255lph,Aem Wideband, 58/63 turbo, megan FPR,Mishimoto rad,3" Apexi turbo back exhaust,Nology Hot Wires, NIStune
- 91_ka24de
Stock fuel pump. So I don't have the iacv so I have to crack the throttle body. Now I'm thinking that when the tbs cracked the tps is sending to much fuel at idel
- street_240sx
- 91_ka24de
how do i do that exactly? and we have the fuel psi at 25 right now.
- street_240sx
turn the psi back up and try this first http://www.nicoclub.com/archives/ka24de ... -idle.html
03 evo8 gsr: stroker 2.3
- Jordan Gladman
What else did you change? Even with the TPS messed and a bad IAV your AF's should be fine.
Check your MAF.
Check your MAF.
- 91_ka24de
So when the cars running I can pull the tps clip and it doesn't affect the motor what so ever. Revs the same as pluged in no stumble or anything. Thinking the tps is bad. And I can't get the right resistance reading while trouble shooting the tps. And I noticed when I unplugg the maf clip while running it will run the samme but won't leme rev past 3grand. Isn't the engine susposed the die after I pull the clip to the maf?
- street_240sx
- 91_ka24de
stock ecu. stock new 02 sensor. my boost guage is reading 11 vac. im pretty sure most boosted cars shouhld be at 21 20 19 vaccume at idel. meaning if im at 11 i have a vac leak. that could explain my ungodly running rich problem maybe?
Did you check the ECU for codes? Could be a CLT problem.
Dave
Dave
NismotronicSA Tuning Package/Powered by TunerCodeSA
Speed-Density Tuning for Nissans
- 91_ka24de
clt? and no i havn't checked it for codes yet. i was showing code 12 which is maf but i replaced it with a buddys and havn't checked it since. i will tonight.
- 91_ka24de
Ok compression is 165 165 150 120
- 91_ka24de
Ok compression is 165 165 150 120.. I built this oem motor. First timer. So don't gimmie to much ****.. what do u guys think? I did not gap this rings accordingly. Vaccume is 11 vac at idel. Runs choppy now. Havnt really run the car to set the rings.... SOS....
- 91_ka24de
Going to do a leakdown test and see what's goin on. But should I pull the motor n redo the rings?
- 91_ka24de
Wet test? Just the same ad a leak down but put oil in?
- 91_ka24de
yah ive got it on disk.
- 91_ka24de
Ok. Lol I pulled all plugs and re did test and my numbers are 180 180 180 124.. doing test tomorrow and ill see if the rings are toast or the hg or valves. Hopefully just hg. (Fingers crossed)
- 91_ka24de
Cylinder 4 leak down test. Fail. All pressure comes out of oil dip stick.
damn bro ight do this do not pull every piston.
just pull that one check the ring gaps on the bad cylinder. if at worst get a new set of ring do a quick hone and put it back togeather and try it again. if the others are fine do not f with them.
i have done this before and it has worked with no problems.
- 91_ka24de
Do I have to have it rehoned with one piston w new rings?
- 91_ka24de
No miles on it. I've just let it idel and reved it to fix all the problems
- 91_ka24de
Honestly. I got no idea how to do that lol. Would be scared to accidently mess it up some how
- Walperstyle
