2871r Breaking Up Under B00ST!
Setup:
2871r
NIStune
Stock Plug Wires
BRK7E
OEM Distributor
15psi
Built Block
O-Ringed Head
So i did a few pulls the other day and it was breaking up pretty good under boost. I would say it did it around 3-4 times. So i stopped obviously, and let the car cool and off brought it back to the shop.
How detrimental could that be on my setup/motor?
Im going to be upgrading my spark plug wires (Magnecore 10mm), and installing new plugs. Along with getting a re-tune once the weather clears up some more.
2871r
NIStune
Stock Plug Wires
BRK7E
OEM Distributor
15psi
Built Block
O-Ringed Head
S14 KA-T2871r
GET GRIP FEELING!!!
Eloquentlytrack.wordpress.com
GET GRIP FEELING!!!
Is there any way you could do some datalogging with Nistune and post it? I'd say it's something like spark blowout. What happens if you lower the boost a little bit?
What are your plugs gapped to? Did this start happening recently or has it been an ongoing issue?
I guess it could be boost leak, what are your AFRs?
^^yepz240xs wrote:well what kinda fuel set up are you giving it, if you arent running proper fuel you bet your rear your gunna break up under boost cause its not getting fuel right
eather its to lean or to rich. what about a wide band?? fuel injectors???
you left a lot out of your post buddy. from the info you have posted. im gunna be a smart ass and say pcm lol. need more info.
stock plug wires suck so id replace them like u said, check cap and rotor too.
currently n/a.
currently n/a.
- redpotatoes
Tuning, boost leak or timing.
I also run the stock wires and never had problems
KA24DET GT2871R .86 Setup:
viewtopic.php?t=44222
- redpotatoes
It gave up at 15 psi and it was built ?
Bad tune?
Bad tune?
