recommend me a turbo please
I just got done rebuilding my KA with forged internals and finally broke it in. JE pistons(+20 over bore), K1 rods, ARP rod, main, and head bolts, with a felpro head gasket.
Now its time for a turbo! I'm aiming for around 400 HP, it's my DD so I don't want to hit boost till around 3500+ rpms. So I was thinking about just going with the very popular t3/t4 50 trim and while searching I saw that the t3 60-1, AKA super 60, was cheaper. I did a bit of research on it a and some say it has really bad lag others say it doesn't. I've never boosted a car so i'm having a hard time choosing, i'm just looking for some opinions on what to get. Let me no what you suggest please!
thanks,
Alex
thanks,
Alex
i currently have a T3/T04E .60 ar compressor .63 ar turbine, turbo should spool ~3500rpm at latest and will support 400hp, for sale for $550, 0 miles on rebuild.
also the super 60 and the t3/60-1 are 2 different turbos, the super 60 is a straight T3 turbo, the T3/60-1 is a T3/T04S(bigger compressor housing than a T3/T04E)
the holset hx35 fits your description
250-500hp with this turbo
hit 12 psi by 3600rpm (~300hp)
can find them for 350$-500$ rebuilt
http://www.turbobygarrett.com/turbobyga ... index.html
Read, read, read. Read Maximum Boost. I hate when people say recommend something for me then you do and they hate it. Then they downplay you saying you don't know sh1t but there the ones asking for help. f*cking annoying.
:bash: :69: :3some:
:bash: :69: :3some:
- k12ispl
get yourself a disco potater
1993 240sx Coupe 5 Speed
*'91 Ka Rebuild w/ stock internals
*Stage 1 clutch
*Lightweight Flywheel
^July'12-Traded for a '03 zx6r 636
1969 Datsun 1600 Roadster Build
viewtopic.php?t=52915
www.intercarofknoxville.com
*Stage 1 clutch
- joshpntbl07
By 3.5k rpm's I was at 15 lb with the 63 a/r then it creeped up to 17ATL240 wrote:Cool, about what rpms were you hitting full boost?Berserker wrote:For street and DD, t3/t04 garret 50 trim is the way to go. I had it and I loved it. Boost will not drop off at higher rpms, go with the .63 a/r they have I believe. Get it tuned for 20 lb and you will have 400 whp.
You can check out my dyno graph here : viewtopic.php?t=43799&highlight=
at 17 lb I went to the track and ran 12.4 @ 118 Then I kicked up the boost to 20-21 lb, But I was stock block with E-85.
Airman and I are running the same turbo but I am on corn. 60 trim with stg 3 .63 a/r wheel. Same time for boost as well. I have 235's out back and starts to let go at 6800.airman wrote:I've got a Turbonetics 60 trim, T3/T4. Boosting 15psi right now my guess ~320-340hp, no traction with stock 195s and open diff so I can't really tell you for sure. I get positive pressure before probably 2.5krpm and full boost by 3.5-3.7k.
http://youtu.be/wCssXCrwqZ8
Good choice on specs but I have read that some PT units wears bearing fast. Just do a quick google search to see how long people have been using them and results.
I traded my turbo for some fubar'd 18 inch rims so I don't know. But my turbo is a "real" hybrid. Garrett 60 trim front with t-netics .63 stage 3 wheel. Is that with shipping? Do a google search for shopping and see if you can find something cheaper from a reputable seller with the same warranty. If not, buy it from them.
Sounds like a good deal.
