thoughts on hacked maf
hello another budget ka-t build here. I'm at the point in the build where I need to do something with fuel/air. I was thinking of hacking the maf. I found this
http://www.ka24development.com/hacked_MAF.html
anybody go this route or no anyone who has?
This is bad because the ECU uses the maf voltage to calculate load, it sees barely any voltage and figures its under low load... Timing gets ramped up and then you are draining pieces of piston out of your oil pan. This is the worst case senario if you dont catch it in time. They also said they went through a few motors due to detonation.
That surely doesnt inspire confidence in these guys abilities. Doesnt sound like the guys are using widebands or anything.
They also said you can do the mod with 370cc injectors then your limit is about 250hp.. I wouldnt be surprised if they blew a motor due to pushing those tiny injectors too far..
Only time i could see it being useful is if you had a standalone and could properly tune the new maf curve. Even then it would be better to just go map.
SAFC's suck balls and why get an N60? Just get an N62 to support up to 500hp or get a p60 with a tune. I don't know why people use the vq30 MAF's.
There is no "they". That is Orion's site. I bet that info has been up there for 8 years. The hacked MAF idea came about a long time ago when there were very little options for tuning. At the time, it was either JWT, standalone, or.... this. It's obviously not the best idea with all of the tuning options available now.schmauster920 wrote:This is bad because the ECU uses the maf voltage to calculate load, it sees barely any voltage and figures its under low load... Timing gets ramped up and then you are draining pieces of piston out of your oil pan. This is the worst case senario if you dont catch it in time. They also said they went through a few motors due to detonation.
You youngin's just don't know how good you got it these days.
Agreedsupakat wrote:SAFC's suck balls and why get an N60? Just get an N62 to support up to 500hp or get a p60 with a tune. I don't know why people use the vq30 MAF's.
SAFC's suck but sometimes people are just dead set on using them...
Going N62 would be more than ideal, but N60's cost next to nothing and gives you a 3" housing to work with and are pretty much all you need for a "budget" setup using a t25 or t28.... from experience you can pull N60's from the junkyard all day for like $12, the pigtail is the same as n62 which makes upgrading painless when funds come in. No where near the best option, but a more simple one compared to hacking a stock maf sensor.
95 240sx KA24DE-T
S15 Injectors
Z32 blow through
S15 Injectors
Z32 blow through
Adding another shady idea to the list..
I dont see why you couldnt try different resistors on the maf info wire going to the ecu, or maybe the power wire. It would be like hacking your maf i would think.
Most people prefer to hack plastic than wiring though.
Yeah +1 for the 12 dollar n60 junkyard maf... i never understood why everyone is running a z32 maf. The n60s are so cheap, if you arent going to make over 350hp anytime soon, then i dont see why not. The extra resolution in the maf signal can only be a good thing.
Not to mention, mafs die every once in a while, so its not like its a one time purchase to future proof your ride.
The issue is that the MAF airflow vs voltage isn't linear. Putting a resistor into the sensor wiring or whatever is a linear change and you could only "tune" a very narrow area of airflow.schmauster920 wrote:Adding another shady idea to the list..
If you are on a budget and don't need big power this can be a reliable mod same as AFC. It just requires you to do more work. If you have conzult, datascan, or an informer you can compare timing modified vs unmodified and retard your distributor the necessary amount. I would only try this on an s14 with an open element or car with similar maf like a maxima or p11.
schmauster920 wrote:Is anyone using a VQ30 maf? I think he meant VH
I meant vg30e. Typo my bad. I am stuck on the vq30's since I can find at least 5 in the junkyard right now. Will be awhile before 35's hit the yard. Great option to swap in.
The vq30's are e61 which might have a better vq map than the n60. Would need to look that up. The vh are p60's. Either run an n62 or p60 imo.
thanks for the imput....what kind of cars does the n60 come on. I only want about 200 hp to do some drifting with and get the back tires spinning. i'm not even registering the car its only to have some fun with but anyway here are my engine mods so far..what do you think.
sr injectors
t3/t4 turbo under 10 psi
fmic
external wg
emissions delete
hks ssq bov
mbc
i don't want to spend all day at the track trying to get it run right I just want something that will work I was thinking an enthalpy ecu and call it a day?
sr injectors
fmic
external wg
emissions delete
hks ssq bov
mbc
