Hesitation Issues
Hesitation Issues
Tried posting this in KA basic, but apparently I'm not authorized?
Anyway...
OBDII KA24DE, n/a
Auto trans
I checked voltages on the white wire of the MAF, 1.7 at idle, 2.6-2.8 at 4000RPM. Obviously doesn't seem right. Cap, Rotor, Plus, Plug wires were all replaced when trying to troubleshoot this. I also cleaned the MAF with no luck.
I had a friend pull another MAF for me. Welp, said MAF did not work. Read 2.6-2.8v, again. So I went out and bought a brand new MAF, 2.6-2.8v at 4000 RPM. Engine grounds show continuity, TPS is checking out.
Yesterday I checked the injectors, replaced the fuel filter, replaced the distributor cap, checked for vacuum/intake leaks, cleaned the IACV, regapped the plugs with note of signs of fouling due to unburnt fuel on all four plugs, also noted that timing was a few degrees off. Retimed the motor and set idle but still having issues only when the motor is warm.
When the motor is cold, things seem to run fine.
When the motor is warm...
Idle = misfire every 30 seconds - 1 minute
Press on the gas slightly = fine
Press on the gas 1/4-WOT = stumbles until 2500 RPM then takes off
Above 2500 RPM = Pulls nice and hard
The thing sounds like a Subaru when on the throttle until it gets going. I like the sound of a flat four, but not in this car, hah. Beginning to suspect a bad coil, but that's in the distributor since it's an s14, right? Ideas/Comments/Opinions? Really need some help here..
Anyway...
OBDII KA24DE, n/a
Auto trans
- carcrzy920
had the same issues, and replaced every thing you did. Turned out it was just the damn fuel pump. let me know if that helps. PLEASE let me know if it helps. Also it wouldnt hurt to stab another dizzy in there. When the mafs unplugged and you WOT it, does it stumble all the way to 2<500? Or does it rev fast then bog at 2,500?
I bought a new CTS yesterday, have yet to put it in though.
carcrazy920, Injectors are fine, plugs are fouling across the bank from unburnt fuel running through them. Wires are new.
s!4beast808, I have to check the fuel pressure. Replaced the fuel filter thinking it might be clogged/restrictive, but maybe the strainer on the fuel pump?
When the MAF is unplugged it will rev fast and then bog around 2500 like it's supposed to. It sounds a bit rough when revving fast, but doesn't sound nearly as bad. Different fuel dumping smell though.
Put in the new CTS and set timing again. No luck
Rev:
http://www.youtube.com/watch?v=E1wkDhEayQ8
Drive:
http://www.youtube.com/watch?v=y3CZraEsXmQ
Rev:
Drive:
Long shot but status of air filter?
- carcrzy920
- carcrzy920
- yojo006
Test the fuel pump, ..test everything, dont keep throwing parts at the car as we all know that costs $money$...i had the exact same problem on my 98 kouki and it to is all stock. My MAF had the same Voltage readings and everything, i even tested my MAF on a friends car and it ran fine....Long story short...it was a an intermittent problem with the MAF after all..i havent had a problem since...oh and Yes, Nissan Altima 9?-98 MAF are the same as the 95-98 MAF's...Good luck. Hope this helps
I was trying to take a look at the EGR and EGR-BPT, but I can't quite remove the EGR valve itself. Might need some swivel sockets or something. Annoying. Any tips on cleaning it once removed?
Also, couldn't be my MAF, like I said, tried three different ones (one being brand new).
Man, it's just becoming a huge headache.
A friend dropped me a fuel rail with FPR I will swap out.
Backtracking to the fuel pump, wouldn't it cause everything to lean out if it was going bad? I've eliminated injectors/o-rings because ALL plugs are fouled, highly doubt all four would fail at once. So I would imagine FPR if anything involved with fuel.
I was also suggested O2 sensor. Recommendation on testing?
- yojo006
Robb wrote:A friend dropped me a fuel rail with FPR I will swap out.
Why dont you just put an inline fuel gauge in the feed line? 2 birds with one stone..1-Fuel pressure from pump 2- making sure the fpr is working properly.
Go to harbor freight. Yea it is probably not 100% accurate but you could just use it to get an idea.
You did everything new so it might point to the ecu. A rare occasion but still happens. Or something stuck in return line. Odds unlikely but you can never tell.
Pump will not foul them out, but regulator will if stuck.
