How far is the clutch slave cylinder supposed to extend the fork when the clutch is depressed?
My car started life as an auto, I didn't swap it, but it doesn't have the clutch piping connector like the FSM prescribes, it goes straight from the slave cylinder to the master. Is this right?
I also have a lot less pedal travel then when I took it out. About half way through the travel does it actually get tension. Obviously this isn't right so what am I doing wrong? I bleeded it as well.
Clutch slave cylinder question
the line can go straight from the master to the slave (most 5speed guys remove the dampener box that usually is between them for easy of bleeding)
you will need to play with the pedal as well, should get resistance shortly after pushing the pedal. slave should have full travel on the fork
If you can push it down some before you get resistance, then there is still air in the system.
Full travel should be around 0.75" but that's my estimate from just watching it. It may be more.
