Bearings
- ppctx
If you look in the specifications, at the end of the engine mechanical section of the fsm and compare both the e and de rod measurements, it will give you a good idea of cross compatibility.
Someone please correct me if I'm wrong, but I believe you should measure diameters first before ordering bearings.
+2.4. Unless you want to waste money.Jmcc wrote:why correct?. you should do it any ways.ppctx wrote:Someone please correct me if I'm wrong, but I believe you should measure diameters first before ordering bearings.
