Finally there is a light at the end of the tunnel..
I just need some help identifying what these plugs do and whether I need them or not.
This first bunch are on the starter loom and next to the battery connection (which has 2 plugs on it??) I guess they go into a fuse box?
This one is on the same run as the MAF plug. Is it for a temp sensor or something?
These 2 come from the main loom just before it goes through the bulkhead, can see anything to plug them in to?
I also have a couple left on the gearbox that dont seem to connect to the engine loom. Can get pictures if needed?
Cheers for any help
Help identify plugs
- R34SR
was this car originally auto then manual? you tend to end up with spare plugs when you do that.
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
Mazworx z32 tranny swap
AEM IGN1A COILS
BW S257 SX-E .78AR
ID1050x Injectors
First pic is fuse box. Second goes to power steering line. last looks like connection under intake mani for iacv and other crap.
Also, the ps connection goes to a pressure switch on our lines. When the steering wheel is turned and pressure is seen, the ECU carries up the idle 100 or so rpm. Thought I would just throw that in.
