Ive been having some issues with my idle
the cars idling good but it is hiccuping, every couple seconds it drops the rpms then goes back to normal. Seems like a misfire or something
Ive been working with a local shop that specializes in 240s to figure it out but we haven't pinpointed it just yet.
We noticed my group strap was missing, so I added another one from motor to body and for the next 3 drives the idle was perfect and the problem was fixed. now it came back again!
Any ideas on what it could be?
Another KA Idle Issue
- LeandroS14
Re: Another KA Idle Issue
I had this problem too since my engine was swapped when it was built.LeandroS14 wrote:Ive been having some issues with my idle
It would feel like the car idled OK when it was cold..but soon after it starts to warm up I would hear the RPMs drop and make a hiccup sound...then it would return...then do it again. I would get in the car and rev it up and hold it and it would still do it.
I checked timing, spark, vacuum leaks, injectors...all clear.
What I had was a "CODE 34 - Knock Sensor". Check for it on your ECU. It wont give you a CEL and thats why I went so long without detecting it. I took care of it..no more code...perfect idle! Try that
- LeandroS14
Just an update, I got another knock sensor harness because mine was messed up and I connected everything, I have to go to the autoparts store today to clear the code. The idle issue seems to go away for a day or so when I disconnect the neg on the battery (resetting the ecu) but that was prior to the knock sensor. Ill update this thread again in a couple days if the issue continues
- LeandroS14
Ok so the problem is back but this time its a little different.
The idle stays smooth and steady with the A/C OFF, but as soon as I flick the A/C ON the idle starts to stumble.
Im also throwing codes
p1400 EGR & Canister solenoid valve
p1401 EGR Temp sensor
I took out and blocked off all the EGR stuff about a year ago
Also when I first turn the car on from a cold start is it very hesitant until the engine warms up a little
- LeandroS14
- wesamiss
I had this exact problem. Ended up being a fuel pump on its last leg. I also replaced the IACV and air regulator, and found a vacuum leak while fixing all this stuff. After replacing all this stuff i put a little seafoam in it. She runs like a top meow.LeandroS14 wrote: Also when I first turn the car on from a cold start is it very hesitant until the engine warms up a little
check the FSM, great place to trouble shoot
CARisma probably has the best customer service I have ever experienced.
WES
- LeandroS14
- LeandroS14
- LeandroS14
