so, i replaced my short block on saturday, and car has been running pretty good. replaced plugs and wires while i was at it. so i drive to work today, and go to start it when i get off, and wouldnt you know it, d@mn thing wont start.
it has had a tendency to try and start up super rich at times, so i pull the pump fuse and crank it, usually takes care of it but not today. it floods out so bad to the point of hydralock.
not throwing any codes. i figure its either i JUST had an injector or 2 crap out (not too likely), my harness is so bad now that crazy things are happening (most likely since harness is in bad shape) or my fpr took a dump.
kinda lost on where to go from here. i think imma pull my fuel rail and see if i got some leaky injectors, put a guage on my fuel line, and then double check my cam timing. if everything checks out, time for a new harness i guess. think i'm on the right track? anyone else have any suggestions?
flooding out, badly
flooding out, badly
95 240, nothing special
Sounds like leaky injector but it should not hydrolock. I hope the rotating assembly is not to blame. Try turning the crank by hand and see what you feel.
- NeverSatisfied
Just to see if it is actually flooding or if it might be something else, pull your plugs and bump the motor. If its flooding as bad as you suspect it will throw up fuel out of the cylinders. If it IS hydrolocked, my money would be that your fpr **** the bed. Just my .02
If its worth doing, its worth overdoing.
