What does cruise control need?
- mattheripper
Do any of you know the s13 well enough to tell me what all is needed to hook up cruise control in a car that never had it. I wanna put cruise in my Skyline and I don't know if everything I need is in the s13 parts car of mine. Just at a glance today I saw the cable vacuum unit and the switch system on the steering wheel. Is there any special circuits or control units?
I would google "how cruise control works" and then google "240sx cruise control" and make relations...
Basically you'll need the cruise control unit, cable, a proper place to mount it, all of the buttons/interface, splicing into brake switch, speed sensor, etc....
Also, why is this in introductions? Moving to Tech. Basic.
- mattheripper
- mattheripper
Well I actually now that you ask have never seen it on a skyline. But I put a ka into my skyline anyway. So I'm thinking it might be just as well to use s13 parts from my parts car then going and spending a few dimes at the import auto wreckers here.
I just think it'd be sick to have cruise control on a car that looks as "shakotan" as mine:)
If he's using the stock KA manifold he should already have the little bracket for mounting both cables.biggie wrote:If not, hardest thing is probably the throttle plate to get the 2nd wire on it.
- mattheripper
I think he was talking about the type of throttle body itself. Because I have two and one has an extra cable fitting on the tb swing arm. Rather than the little bracket you mentioned. Cause yeah on all three of my ka's the stock mani's have the two cable bracket. But good point since I put a different plenum on.airman wrote:If he's using the stock KA manifold he should already have the little bracket for mounting both cables.biggie wrote:If not, hardest thing is probably the throttle plate to get the 2nd wire on it.
- mattheripper
No problem biggie. Confusion totally makes sense, sr swaps hardly happen to these things let alone a ka lol
viewtopic.php?p=478893#478893
Heck yes I do. No ones interested in it though haha. I do need to do some updates though.Freise wrote:yeah that's got me curious, OP got a build thread at all for this thing?
- nismoautoxr
The KA cruise control is a pretty simple system . It needs a speed signal , a brake lamp switch signal , a clutch switch signal, power ,ground, and a cable to the throttle . The speed signal typically comes from teh buffer on the instrument cluster which recieves a raw signal from the VSS and converts it to what the cruise and ECU needs . Im not sure if it needs an RPM signal but without looking I wanna say no.
Ricky Ragan,
- mattheripper
Simple actually might be pretty hard. Reason being I swapped out the speed sensor in the ka tranny for a rb cable driven speedo unit. I'm not sure what a VSS is, is it the part I switched. If so do you have any ideas of how I could get around it? I thought it just ran on vacuum, like it reads of the manifold when it starts and just mimics it till its turned off again. But that'd be way to simple to be realistic. Hmmm.nismoautoxr wrote:The KA cruise control is a pretty simple system . It needs a speed signal , a brake lamp switch signal , a clutch switch signal, power ,ground, and a cable to the throttle . The speed signal typically comes from teh buffer on the instrument cluster which recieves a raw signal from the VSS and converts it to what the cruise and ECU needs . Im not sure if it needs an RPM signal but without looking I wanna say no.
- mattheripper
- nismoautoxr
some of the old maximas had a speed sensor built into the speedo cable . That might be an oprion other wise you may check into dakota digital and see what they have in that area such as a speed sensor that also has a cable drive .
Ricky Ragan,
- mattheripper
