I need info from a few people from both 95-96 & 97-98 S14's.
The low pressure hose the runs from the compressor to the firewall. I need to know the yr of your car and the wrench size of the connection near the firewall/brake booster.
My line is busted due to heat and I seem to remember the fitting being a different size than my original one when I replaced the A/C system years ago.
I just moved and now I'm dying in the Texas heat!! Thanks much guys!!!
Bret
Need help..A/C question
Supertech pistons (10.5:1), eagle rods,
cometic headgasket
Precision T3/T4
mild p&p, pdm tri-flow turbo cams, custom exhaust, ETS mani and dump
Fully balanced rotating assembly, ACT clutch
AMS Fuel Kit (65lb injectors), meth/water injection, ebay fmic,
elec fans, z32 brakes, AEM EMS
360WHP
cometic headgasket
Precision T3/T4
360WHP
Thank you, but Im not worried about getting it off. I need to replace the hose but I don't know which one to order. So I need to know the size for both 95-95 and 97-98.
I just need a few good people with S14's to check the approximate size...and let me know.
Soon please!!!! it's in the 90's everyday here with humidity above 40%
Thanks guys!!
----Need to know the year of your car and the size of the fitting-----
Thanks guys!!
cometic headgasket
Precision T3/T4
360WHP
cometic headgasket
Precision T3/T4
360WHP
Guys.....really, no one owns S14's anymore? I just need you take a quick look please.
cometic headgasket
Precision T3/T4
360WHP
cometic headgasket
Precision T3/T4
360WHP
- nismoautoxr
my factory low side AC line on my 95 has a nut that measures 1 and 3/8ths" from flat to flat ( bigassed crescent wrench basically) The tube size is #12. Feel free to google the metric conversion .
Ricky Ragan,
Thank you very very much! I will see if that matches mine when I get home later tonight. Thank you again!
cometic headgasket
Precision T3/T4
360WHP
cometic headgasket
Precision T3/T4
360WHP
- nismoautoxr
LOL...thats the problem. I don't know which one I need. I didn't get a chance to measure mine last nightnismoautoxr wrote:Make me an offer . I might sell you mine .
cometic headgasket
Precision T3/T4
360WHP
cometic headgasket
Precision T3/T4
360WHP
